different fuses
Old Sep 29, 2004 | 09:47 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
different fuses
there are 2 fuses for the radio correct?
could not having one in cause my deck not working?
Old Sep 29, 2004 | 11:05 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
If you are talking about the stock stereo radio system on your car, yes there are two fuses. One is the "ACC" fuse and the other one is the "RADIO" fuse. The "ACC" fuse supplied power for the radio clock and the "RADIO" fuse supplied power to the radio with the key in the "RUN" or "ACCY" position. There is also a brown wire that runs from the light switch to the convenience center to the radio for the "DIM DISPLAY" signal. If the radio fuse is blown the radio won't work and the power antenna (if equipped) won't work either.
Old Sep 29, 2004 | 11:08 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
ok i only have one of the fuses in, i believe it says acc, if i don't have one in (10 amp) could that be a reason my deck won't work?
Old Sep 29, 2004 | 11:10 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
UH! HUH!
Old Sep 29, 2004 | 11:20 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
ok because my stock stereo worked, but the deck doesn't
so could that still be a cause
Old Sep 30, 2004 | 03:31 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
ehh ok i guess i might of crossed the 2 gray wires.
gm really needs to use different colour wires
Old Sep 30, 2004 | 05:48 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
oh man is it nice to be able to listen to cds again
Old Oct 1, 2004 | 12:34 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Humming to yourself offkey gets old fast doesn't it?
Old Oct 3, 2004 | 06:45 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
never
lol, i never hummed just lisnted to the sound of my car
Old Oct 3, 2004 | 06:56 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
3rd gen money
Oct 11, 2019 09:57 PM
thunder57
Nov 7, 2015 02:28 PM
AmorgetRS
Sep 28, 2015 09:33 PM
lanceflame44
Sep 25, 2015 12:28 PM
gta892000
Sep 16, 2015 12:37 AM
