What the windshield wiper cover PN?
Old Jan 8, 2005 | 11:07 PM
StealthElephant's Avatar
Car: 87' Iroc
GM P/N 22039684 is what I found with a search, but I tried looking it up and have found nothing. From what I've seen plenty of people have had the problem (my wipers turn on, but don't turn off unless I put the key in the off position then back on)
Did GM change the part number? Is it still available?
Old Jan 9, 2005 | 12:32 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Try looking it up again. 22039684 if you have pulse, 22039683 if you don't.
Old Jan 9, 2005 | 10:44 AM
Car: 87' Iroc
How do I know if I have pulse or not? Can I check my RPO codes or can it be visually identified?
Old Jan 9, 2005 | 12:37 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
There's an RPO code, but I don't recall what it is offhand. Pulse wipers = interval wipers = delay wipers = whatever name you want to call them.
Old Jan 9, 2005 | 01:42 PM
Car: 87' Iroc
CD4 : WIPER SYSTEM WINDSHIELD, PULSE
That is on my RPO sticker in my center console. So what does this mean for me? I just need the 22039684 cover? Is it difficult to install or very simple?
Old Jan 9, 2005 | 03:05 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You should have the pulse wipers then, so you'd need 22039684. The cover is easy to change, there are a just a few torx screws holding it on. You'll just have to make sure that the little spinning arm inside for the park switch is in the right position before you put it on.
Old Jan 13, 2005 | 05:55 PM
Car: 87' Iroc
How similiar is the pulse cover to the intermittent cover? There is a guy runs a 3rd gen junkyard in his back yard about 15 miles where I live, I've picked items up from him before. Do the covers look exactly the same or will I be able to tell the difference.
I'm going to guess that GM charges an arm and a leg for the damn cover.
Old Jan 13, 2005 | 10:34 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Externally the covers are nearly identical, but the electronics inside are entirely different. To give you an idea, the list price on the regular cover is something like $15, and the pulse cover is something like $80. Sometimes there's a sticker on the cover with the P/N on it, but not always. If you look at the electrical connectors, I believe the regular cover is missing one terminal that the pulse cover has. The easiest way would probably be to look at the car that it came out of and see if it has the pulse setting on the wiper control.
By the way, you can put a regular cover on. The wipers will work fine in the normal, fast and park positions, but will stop dead in their tracks on the delay setting.
wigmobile
Feb 26, 2025 02:56 PM
Veaceonee
Sep 29, 2016 08:15 PM
codeysabatini
Nov 10, 2015 04:07 PM
adelane
Sep 9, 2015 08:51 PM
scottmoyer
Sep 7, 2015 07:06 PM
