Electric Choke Fuse and Relay
Old Feb 11, 2005 | 07:54 AM
HorseflyDF's Avatar
Car: 86 Camaro Z28
Engine: 350 sbc goodwrench
Transmission: T-5 in the works
Axle/Gears: 10 bolt 3.42 open
I cannot locate a fuse that is labled choke under
the dash also I cant locate the relay..
Anybody have pics of it?
I have a black lead going to the choke which isnt sending
any power when the engine is running (holley 2160)
Old Feb 12, 2005 | 01:58 AM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
The relay is located in the 'convenience center', above your right leg when sitting in the car. It's a panel that drops down similar to the way the fuse block does. The fuse is marked simply as 'C/H' and is located in one of the corners on the same side as the silver circuit breakers.
The original choke wire would be light blue in color. The Holley may require a wire to ground for the choke element to function.
Old Feb 12, 2005 | 02:01 AM
HorseflyDF's Avatar
Car: 86 Camaro Z28
thankyou for that info
the wire thats goin to the choke now is black?
Ill look for the things you pointed out..
Old Feb 15, 2005 | 05:29 AM
HorseflyDF's Avatar
Car: 86 Camaro Z28
I ran jumper wire from the bat
to the choke and the choke opened
up slowy so its still good.
How do you set up a safe
hot wire and relay for the choke?
Old Feb 16, 2005 | 01:22 AM
HorseflyDF's Avatar
Car: 86 Camaro Z28
had to post it again
because I figured this car didnt originally have an
electric choke . Theres no fuse marked for it .
I put up a new post for help on this subject running
an electric wire to the choke correctly .
thanks
Dave
Old Feb 16, 2005 | 01:42 AM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
thanks
Dave
What year and model is your engine? It is important for the right answer.
P.S Stop beating your wife!
Old Feb 16, 2005 | 01:47 AM
HorseflyDF's Avatar
Car: 86 Camaro Z28
all i know is its a 350 small block
and I dont know how to verify that.
guess i better start looking for numbers on the block
where would be the easiest place to find numbers for
the engine?
Old Feb 17, 2005 | 07:49 AM
HorseflyDF's Avatar
Car: 86 Camaro Z28
I cant find numbers on the engine
I found a website they have all the engines
to bad i cant find numbers I ll keep trying
http://www.cehighperformance.com/new_page_3.htm
I need to run a wire from the fuse box
to the choke I found this on previous thread
but isnt there suppose to be a relay also
so the choke doesnt burn up?
Old Feb 20, 2005 | 10:45 PM
HorseflyDF's Avatar
Car: 86 Camaro Z28
I had to wire up a line from the fuse box
to my choke I didnt use a relay because I dont know
how never did it before.
The choke only gets power when I turn the key to the on
position , this was working fine until my guages blew out
again. The fuse for the gauge was blowing before
I wired up the choke. I cant find the problem ..
MY Camaro has alot of electrical
problems and IM not the only one.
seems like everyday someone
post problems .
I think I made a mistake
should of stayed with the imports
I have and 89 celica no problems ever and it has 200,000 miles.
not one electrical problem just shows quality it was built in
Japan.
I like the way the camaro looks and drives but Im getting
frustrated personally I messed up buying this car.
Im not gonna give up yet. ill tear the wires out andput aftermarket guages the cpu isnt doing much anymore anyway.
AmorgetRS
Sep 28, 2015 09:33 PM
Johnoooooo
Sep 22, 2015 08:55 AM
gta892000
Sep 16, 2015 12:37 AM
64goatman
Sep 9, 2015 01:09 PM
