Battery In Trunk
Old Mar 15, 2005 | 10:26 PM
outlawracer's Avatar
Car: 82 camaro berlinetta/87 sport coupe
Engine: 87 LG4 305
Transmission: world 5speed
Battery In Trunk
i was wondering where you guys placed your battery in your trunks. i want to do that i just wanted some ideas. thanks guys
Old Mar 15, 2005 | 11:16 PM
Kandied91z's Avatar
i had mine originally where the spare tire use to be to keep weight in the right location. now i have two on each side though.
Old Mar 15, 2005 | 11:26 PM
steve87iroc's Avatar
Car: 1987 iroc z
Engine: 355 dart platinum 215cc heads
Transmission: <<BLOWN UP TH400>>
Axle/Gears: 10 bolt 4.11's
here is mine i have to get a new box though plastic piece of crap.
Old Mar 15, 2005 | 11:27 PM
Car: 1987 iroc z
here is the cut off switch.
Old Apr 4, 2005 | 05:20 PM
GTA Ryder's Avatar
Kandied91z, what in the world are you doing with 4 batteries??
And, a question for all of you....is there anything that changes when moving the battery to the trunk??
I plan on moving mine to my trunk, and just wanted to make sure like it does not affect anything.....i am assuming nothing changes....just, the pos. cable running up to the front of the car and attaching to everything under the hood as normal...
Thanks!
Old Apr 4, 2005 | 05:54 PM
Kandied91z's Avatar
what should change? everything runs and works normal if you hook it up correctly if that's what your asking. cleans the engine bay and of course moves weight but beyond that nothing else special. i did it for room under the hood more then anything.
Old Apr 4, 2005 | 06:13 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
IM on my way of doing it too. Steve87, i see that im not the only person that took the carpet out and there was that one square foot of material that wouldnt come out.
Did yall guys run your wire under the car or in the car?
Old Apr 5, 2005 | 07:58 PM
Car: 1987 iroc z
i ran my postive wire on the inside of the car along the passenger side and i routed the kill wire right with it.
1.
Old Apr 5, 2005 | 07:59 PM
Car: 1987 iroc z
2.
Car: 1987 iroc z
last one
Old Apr 5, 2005 | 08:22 PM
adambros's Avatar
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
If you've got a dry cell battery and don't have to deal with tech inspections at the track the BMR mount makes for a clean install.
http://www.bmrfabrication.com/F3-misc.htm
Old Apr 5, 2005 | 10:56 PM
Car: 1987 iroc z
do you think they would say anything about it right i dont have the top to it broke.
Old Apr 5, 2005 | 11:13 PM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
Here's mine...
Must be certified hardware and be vented to the exterior for track legality. Cutoff switch must kill engine.
Attached Thumbnails Battery In Trunk-c-documents-settings-hp
Old Apr 6, 2005 | 01:21 AM
Cyfun's Avatar
Car: '83 Trans Am, Black on Red
Engine: LG4 305ci V8 w/ CCC-Qjet
Transmission: Rebuilt 700r4
Axle/Gears: 4th gen 2.37 posi w/disc brakes
Steve, is that a drycell in there?
Old Apr 6, 2005 | 02:36 AM
Car: 1987 iroc z
yes its a optima yellow top.
Old Apr 6, 2005 | 04:08 AM
Cyfun's Avatar
Don't think you need to worry about venting it, then. Might not need a lid, either. If ya do, just cover it with saran wrap.
Old Apr 6, 2005 | 12:18 PM
Car: 1987 iroc z
good thinking
Old Apr 6, 2005 | 05:21 PM
JMatlock88's Avatar
Car: 1991 Formula
Gel Cell, Dry Cell, Sealed Batteries still all have to be in an approved box vented to the exterior. Mine is an optima in there as well.
Old Apr 6, 2005 | 07:52 PM
Cyfun's Avatar
No kidding, that's lame. I still like the idea of hiding it in the spare tire well, then getting one of those 2 lb display batteries from Checker and mounting it up front like it were the real battery.
Old Apr 6, 2005 | 09:03 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Old Apr 7, 2005 | 02:00 AM
Cyfun's Avatar
I was reading about that in another thread. Some guy had the idea to hide the battery in the spare wheel well and conceal the wiring really well, then go down to the local auto parts store, ask for one of the hollow display batteries that they keep on the counter for people to look at, then mount it in the car as if it were the real battery. They only weigh a pound or two.
When you're at the track and the inspectors pop the hood, they only see a battery in the battery tray, with red and black wires coming off of it.
Old Apr 8, 2005 | 11:41 PM
WhiteKnight's Avatar
Car: 88 GTA
Transmission: Manual
haha thats a wicked idea. gotta try that one
Falcon50
Aug 22, 2020 03:26 PM
3rd gen money
Oct 11, 2019 09:57 PM
RS Reaper
Oct 17, 2018 07:52 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
drumstixer
Sep 29, 2015 03:02 PM
