Turn b/u fuse
Car: Yellow/Black 1987 Z28
Engine: 355 Carb
Turn b/u fuse
hey guys. all of a sudden my turn b/u fuse keeps blowing. i disconnected the nuetral safety switch and put a fuse in and it didnt blow. it seems to be when you have the safety switch connected and shift into reverse it blows. i put in a 25 fuse instead of the 20 and now its not blowing. any ideas?
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Check the dark blue wire at pin "C" of the park/neutral switch. It runs from there to pin "B" of the turn signal flasher and from there to the turn b/u fuse. BTW, I wouldn't leave that 25 amp fuse in there as it might cause more problems to the circuit.
Engine: 355 Carb
i checked the wire it all looks fine?! it also blew that 25 on the way home from work. i dont know where it is shorting out. how can i find out whats wrong?
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Not to hijack the thread or anything, but I'm having a problem with the same circuit. As soon as I put the key in run, the circuit blows - Trickster, would you happen to have the wiring diagram of the Turn B/U circuit, and it's 20 amp glory?
I think that will also help this guy out
