switch under dashboard
Old Apr 15, 2005 | 09:09 AM
HasseO's Avatar
Car: -88 TA GTA
Engine: 350 tpi
Transmission: TH700
Here comes a novice question:
Whats the switch under the dashboard on the drivers side for?
Whats behind the cover?
Old Apr 15, 2005 | 10:53 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Which switch are you referring to? The dimmer switch or the ignition switch that is located on the steering column. Do you have a location of it & a picture? What year & model car is it?
Old Apr 15, 2005 | 12:57 PM
HasseO's Avatar
Car: -88 TA GTA
Engine: 350 tpi
Transmission: TH700
Its a 85 TA 305cui lg4
Attaching two images showing the switch and the "cover"
thanks
Hasse
Old Apr 15, 2005 | 01:01 PM
HasseO's Avatar
Car: -88 TA GTA
Engine: 350 tpi
Transmission: TH700
second image
Old Apr 15, 2005 | 01:14 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
That aint a factory switch, so it's impossible to tell you what it might be for. Where do the wires go? It could be a ghetto tq lockup switch, it could be for an alarm, it could be for an 800 hp shot of nitrous...
Old Apr 15, 2005 | 01:21 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The only thing that would normally be in close proximity to that area is the ALDL and the convenience center. You can tell by looking at the three holes drilled in the dash that something else was added there and removed at some point in time. Have you tried pushing the switch to see what might happen?
Old Apr 15, 2005 | 02:29 PM
Zed'er's Avatar
Car: 84 Z28HO
Engine: 350 summit block
Axle/Gears: 3.73 10bolt
It looks like a brake controller for a trailer.
Old Apr 15, 2005 | 02:37 PM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
Its an eject switch most third gens came with them, theres a parachutte in your seat.
Old Apr 15, 2005 | 02:49 PM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
o wait sorry, the one under the dash is for your oil slick to make people chasing you wreck
Old Apr 15, 2005 | 03:59 PM
zap89's Avatar
Car: 1989 Formula
Transmission: Finally a working 700R4
I have one on my bird. The guy who had it before put in a manual switch for the cooling fans. If I flip it, it will keep the fans on all the time. Maybe the same on yours ?
Old Apr 16, 2005 | 02:06 AM
HasseO's Avatar
Car: -88 TA GTA
Engine: 350 tpi
Transmission: TH700
what about the cover/hatch or whatever its called(excuse my bad english)
Old Apr 16, 2005 | 07:27 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
As far as I can tell, it's simply the cover for the computer port--pops right off. Your English is fine, by the way.
JamesC
Old May 17, 2005 | 06:05 AM
BRobinson's Avatar
Car: 82 Camaro
Transmission: TH-350
Axle/Gears: 3.08
Firebird, huh? Looks like the Turbo Boost.
Veaceonee
Sep 29, 2016 08:15 PM
RacerM
Sep 28, 2015 04:25 PM
327IROC85
Sep 23, 2015 12:11 AM
gta892000
Sep 16, 2015 12:37 AM
Randomtask2
Sep 10, 2015 08:37 AM
