No dash lights...radio twitches....
Old Jun 14, 2005 | 05:22 PM
PDubs87Z28's Avatar
Car: 87 Z28 Hardtop
Engine: 305ci-4bbl
Transmission: 700R4...3.27 posi being installed
i replaced the carpet in my Camaro with new carpet. I removed everything from the car and then put everything back in the way that i had it. after i put the console in i notice the indicator light was not working then but radio started to twitch (shut off and turn back on) THEN my dash/climate control lights blew out....whats causing this?
Old Jun 15, 2005 | 07:40 PM
Skunkmang's Avatar
Car: '87 Trans AM
Transmission: M5
I had somewhat of the same problem with mine, but mine would periodically go out and then come back on then go out and back on. it ended upp being my dimmer switch, maybe pull it out and inspect it for any damage, or mine was fried and i could smell it. i replaced it and have had no trouble since.
Old Jun 16, 2005 | 04:10 PM
PDubs87Z28's Avatar
Car: 87 Z28 Hardtop
Engine: 305ci-4bbl
would that be the cause of the radio going out
Old Jun 16, 2005 | 08:27 PM
Skunkmang's Avatar
Car: '87 Trans AM
Transmission: M5
well no, i thought you meant just the lights on it... i have no idea then sorry.
Old Jun 16, 2005 | 10:51 PM
Notplayn's Avatar
Car: Depends on the day!
Engine: the kind that runs on money
Transmission: One that holds up, I hope
Have you gone back and checked any place where a interior trim screw could have nicked a wire. Sounds like a short somewhere. I know on these cars there is a bundle of wires that run down the drivers side under the carpet retainer panel and behind/under the radio pod. Good luck
Old Jun 17, 2005 | 05:45 PM
PDubs87Z28's Avatar
Car: 87 Z28 Hardtop
Engine: 305ci-4bbl
i got the trim off on the driver side of the car and no wires seem pinched or anything.....tomorrow im taking the radio out and checking back there...then im sneaking under the dash to check everywire....i hope something works....i was drving last night and it was pitch black in my car i need to see my gauges! all fuses are fine...gauges still work normally...heat works....but the radio finally crapped out on me wednesday and it hasn't come on since.....
Old Jun 19, 2005 | 07:52 AM
84ZMIKE's Avatar
Car: 84Z28
Engine: 0.030 over 10.25:1 dart heads 350
Transmission: T 5 W.C. now
Axle/Gears: 3.73:1
make sure you didn't hook the ground for your radio to the power supply for the light........that is a common problem with our cars.....I found out the hard way.......if you have a stock set-up then I'm not sure......good luck
Old Jun 19, 2005 | 11:33 AM
Skunkmang's Avatar
Car: '87 Trans AM
Transmission: M5
What about the illumination wire in there, there is a wire that is connected to the dimmer switch to dim the lights on the radio as well... i don't have my haynes here or i could probably tell you what color the wire is.
Old Jun 19, 2005 | 11:45 AM
84ZMIKE's Avatar
Car: 84Z28
Axle/Gears: 3.73:1
the wire is black/dark brown....it will read as a ground...untill you turn the lights on.....then there is power to it
Old Jun 19, 2005 | 02:09 PM
PDubs87Z28's Avatar
Car: 87 Z28 Hardtop
Engine: 305ci-4bbl
the dimmer light isn't hooked up....i got a pioneer head unit in....i didn't hook up the wire because theres no point. i didn't have a problem with it until i took out the console. I gotta go through ever thing...im ganna literally crawl through there and check it out lol.....i think the dimmer switch might be shot because when the lights worked you'd have to keep the dimmer up almost before the interior light come on or they would twitch out as well...
Old Jun 23, 2005 | 03:30 PM
PDubs87Z28's Avatar
Car: 87 Z28 Hardtop
Engine: 305ci-4bbl
got the radio working.....now i pretty sure the dimmer switch is shot i gotta take that apart tomorrow.....will any chevy dealer have that or is it special order type deal?
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
86IROC112
Nov 7, 2015 06:50 AM
Fanatic1074
Oct 2, 2015 03:47 PM
lewandom
Oct 1, 2015 08:15 AM
Eric-86sc
Sep 28, 2015 11:37 AM
