fog lamps don't work; HELP!
Old Jul 27, 2005 | 08:06 PM
alxtre99's Avatar
Car: 91' Camaro, 71' MERCEDES
Engine: Camaro 3.1L
i have a 85' trans am and when i first bought the car the fog lights didn't work but in a week or so they started to work. then after 2 days they stoped working again. the indicater light for the switch doesn't light up eather but the rear defroster and hatch release both work fine.... i bought a new relay for the fog lamps but i don't know exactly where it goes, any help would be great, thanks, ALEX
Old Jul 28, 2005 | 02:57 AM
defpony's Avatar
Car: 85 iroc z28
i got same problem, they never worked when i bought the car, then they worked ONCE. now they wont work again.
Old Jul 28, 2005 | 07:56 PM
crapper_mekanic's Avatar
Car: 1985 Trans Am/ Recaro w/webbed headrests (AS5)?
Engine: Code F
Transmission: 700, shame, ain't it?
Axle/Gears: 3.27 Borg-Warner posi
foglights
On the left (driver's) side of the engine compartment there is a relay on older models that operates the foglights. More often than not, I have cracked open these relays to find a pile of rust! You may also want to check continuity on the switch, but the relay contact lights the switch, and I have rarely seen that be the problem. Also a word of caution when changing bulbs, don't get any fingerprints on them, and be careful re installing the bezels inside the nose, you don't want a short!! And mine has 3.27 Borg Warner posi, 3.25 sounds kind of odd, but I don't have the Haynes table in front of me.
Old Jul 28, 2005 | 08:08 PM
alxtre99's Avatar
Engine: Camaro 3.1L
thanks for that advise, i'll check on the rear end specs too, lol.
Old Jul 28, 2005 | 08:26 PM
defpony's Avatar
Car: 85 iroc z28
what does the relay look like
Old Jul 29, 2005 | 11:43 PM
alxtre99's Avatar
Engine: Camaro 3.1L
i changed the relay, checked the lights and the switch but still no working fog lights, what eles can i do? i also made sure the running light switch was on, lol.
Old Jul 30, 2005 | 03:08 AM
defpony's Avatar
Car: 85 iroc z28
i found something out tonight, when i have highbeams on the foglight switch will glow blue when i have it flicked down. But when i dont have highbeams on the fog switch light doesnt turn on.
But the actual fog lights dont come on in either case.
I will have a look for that relay in the morning.
Old Jul 31, 2005 | 04:39 PM
alxtre99's Avatar
Engine: Camaro 3.1L
any other suggestions?
Old Jul 31, 2005 | 06:28 PM
Engine: Code F
foglights
Do you have a manual with wiring diagrams in the back of it? Mine is in the shop with the car at the moment , I'm rolling in the spare tranny and and sending "Trannysaurus Rex" down to Louisiana this week. Refer to the diagram, and check the wires by color to make sure you have the right one. Also, in the wire loom down on the frame rail by the battery (left side) there are fusible links that are usually red with a white or silverish stripe. You can either replace the link, or splice in a regular piece of wire and find a better place near the firewall to splice in a weatherproof fuse holder, of course, you will have to lengthen the feeder, unless there is enough wire provided with the holder. And P.S., defpony, the foglights are wired in a manner so they DO NOT operate when the high beams are on. (or at least they should be). This is against the law. There are two very important tools you really should have, they are a 12v test lite, and a good middle of the road automotive multi-meter. Mine even has an attachment to hook around a wire to get an RPM reading
Old Jul 31, 2005 | 07:20 PM
defpony's Avatar
Car: 85 iroc z28
yeah but my car has been converted to RHD, so who knows how they've rewired things.
Old Aug 2, 2005 | 09:52 PM
Droptop_Z's Avatar
Car: 88z
Transmission: t-5
I am also having similar problems with my fog lights. I am gonna try changing the bulbs first. What is the easiest way to change them, as in which screws to remove? Thanks
Old Aug 2, 2005 | 10:27 PM
defpony's Avatar
Car: 85 iroc z28
i could only access 1 plug that was located on the firewall on the very left hand side, i unplugged it and it was full of grease and im pretty sure 1 wire wasnt making contact.
I dunno what this plug is for, but it was pretty dirty, i cleaned it a little bit and tried to push the loose wire back in, but i dunno if i fixed anything, the fog lights still dont work.
The plug consisted of 5 wires, 4 brown and 1 green.
Old Aug 9, 2005 | 03:25 AM
sheltonw3's Avatar
Car: 91' TRANS AM Modified
Engine: Classified
Transmission: Auto with Overdrive
its possible that the main on/off switch could be bad ,mine burned out while I was driving it sorta melted a bit and then I turned it off before it melted into a lock on position or the main power lead wire might be corrupted with corrosion and might need to be replaced?....these things do happen!
Old Aug 9, 2005 | 07:28 PM
Engine: Code F
If you've been switched to something other than the stock wiring, this definitely means a test lite, and jumper leads, because diagrams may not help you. Tracing the wires out can help, because hopefully they may connect to the stock harness somewhere. If not, cutting the power and using an ohm meter to check continuity between terminals might be your best bet, and don't forget the duct tape and a sharpie! As for removing the fog lights, there are two torx head screws that hold the clamps for the lamps. Maybe T-15 or T-20, can't remember. I hope this info helps, and please read prior posts for other useful info.
BRoss99
Aug 10, 2025 05:08 PM
jaridjohn
Jul 8, 2024 03:49 PM
TheExaminer
Aug 26, 2015 04:59 PM
mustangman65_79
Aug 12, 2015 06:39 AM
Omega
Aug 10, 2015 10:24 PM
