ALDL pins E and M
Car: 1989 Trans Am
Engine: 1989 305 TPI
Transmission: 700-R4
Axle/Gears: 2.77 10 bolt
ALDL pins E and M
Hi all,
What's the difference between these two pins? From what I saw on an 1989 Trans Am wiring diagram, these appear to be are exactly the same. Can anyone confirm or deny this? If they're the same, why have them both in the first place?
Car: 1989 Iroc-Z
Engine: 5.7L TPI
They are both information terminals from the ECM and pin "M" is actually a wire spliced to pin "E". The difference is the baud rate of the signal.
Car: 1989 Trans Am
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The two different baud rate signals that I mentioned are 160 (pin "E") & 8192 (pin "M") are used in scan tools and if you will go to the link below you will get a better understanding of what I meant.
https://www.thirdgen.org/techbb2/sho...hreadid=275242
This link is under the DFI & ECM forum and more can be found about it by searching that forum.
Car: 1989 Trans Am
Ah, well if it's the same signal on both E and M then I'll do my wiring with the splice from M to E.
Thanks for clearing that up for me!
