PLEASE HELP IM LOST...
Old Aug 20, 2006 | 04:40 PM
pandemic_ratio's Avatar
Car: 1992 RS Camaro
Engine: 350 small block V8
Transmission: icky automatic
I NEED TO FIND THE "STARTER ENABLE RELAY" DOES ANYONE KNOW WHERE IT IS LOCATED ON A 1992 RS CAMARO? IM SO LOST...
Old Aug 20, 2006 | 06:02 PM
j dezzy's Avatar
Car: 87 TA
Left side of steering column, behind the lower dash pannel, mounted in the relay box.
Old Aug 20, 2006 | 06:13 PM
Car: 1992 RS Camaro
THANK YOU!!!
Old Aug 20, 2006 | 06:14 PM
j dezzy's Avatar
Car: 87 TA
Old Aug 21, 2006 | 11:05 AM
Car: 1992 RS Camaro
ok still need help
im not sure whats wrong with my ignition system now...it starts and stays running only when the key is in the start position but when the key turns back to run the car shuts off...any clues? (this is a 92 RS camaro)
Old Aug 21, 2006 | 12:32 PM
j dezzy's Avatar
Car: 87 TA
sounds like your ignition cylinder is bad.
Old Aug 21, 2006 | 12:37 PM
Car: 1992 RS Camaro
we have 12 volts to the coil so i dont think so... it seems as if im not getting any spark advance but im not sure how to fix that problem either
Old Aug 21, 2006 | 01:44 PM
j dezzy's Avatar
Car: 87 TA
may have a bad connection some where along the distributor, coil, or alt. or possibly a vacuum leak...
Old Aug 21, 2006 | 02:23 PM
Car: 1992 RS Camaro
do you know where i could get an ignition wiring diagram?
Old Aug 21, 2006 | 02:43 PM
j dezzy's Avatar
Car: 87 TA
If that doesn't help you I have a haynes manual with another electrical diagram in it. it's better but my scanner isn't working. I might be able to take a picture of it with my camera though. LMK
Old Aug 21, 2006 | 02:57 PM
j dezzy's Avatar
Car: 87 TA
there ya go. I took the picture with my camera. but it's still readable. this is a better diagram too.
Old Aug 21, 2006 | 09:21 PM
Car: 1992 RS Camaro
ok after some more frustration and a little digging we found out that when the mechanic redid the valves the ground wires were not hooked up to the back of the head .... so if anything like this happens to you all now you know.
Bigboi
Aug 6, 2015 08:51 AM
TC3G89
Mar 1, 2014 02:34 PM
jake.sala
Jan 30, 2013 04:31 PM
pvr007
May 11, 2012 09:59 PM
91camaroRS3.1
Apr 10, 2012 12:29 PM
