temp gauge question
Car: 86' Z28 Camaro
Engine: 350 holly 650cfm carb
Axle/Gears: 3:73 posi
temp gauge question
one day i started my car and i notice my temp gauge was going crazy.it was spasming out and it got stuck up, but wen i turned the car off it went back down.ever since then it hasnt worked.wut could be the problem.is it a fuse or eletrical or something else.please help
Car: 86' Trans am
Engine: 85 LG4-non cc carb(building a 350)
Transmission: Rebuilt 700R4,vette servo,2200stall
Axle/Gears: 2.73 Posi
wire, fuse, or its most likely the temp sensor
Car: formula
Engine: 305tbi
my oil pressure guage did that and then got stuf for a bout a year. It would go down when the car was off.
It was no tthe sensor for me though. i think that it is a short. i messed around under the dash to wire up a few things and now it goes from zero to over 60 all of the time.
Its like it is working properly but the range that was about 30~50 is now 0~60. if that makes sense.
Car: 1987 Formula/ 1990 Firebird
Engine: 5.0 Vin F/ 3.1 Vin T
Transmission: 700R4 in both
Axle/Gears: Haven't checked
unhook the sensor wire. the guage shouldread cold. then jump the sensor wire to a ground and it should read hot. if this happens replace the sensor.
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
The sensor is on the ds head between #1 and #3 cylinders and has a one wire connnector. Take the connector off and the guage should go to zero. Touch the connector to the engine block/head and the guage should go to max.
Car: 86' Z28 Camaro
so today i found out that my gauge is still working casue wen i went to start my camaro it was moving up and down. so could there be a loose wire or do i need a new sencor?
Really, I would check the wire real good. It's sitting right there by the hot exhaust manifold so it has a tendency to sometimes maybe touch one, melt through the insulation and ground out. As it vibrates on the manifold what you'd see on the gauge is the needle going nuts. Maybe eventually the wire would crispify enough to get brittle and break. You'd then see a dead gauge.
Anyway, all I'm saying is that the wire is the weakest link in that circuit. The gauge is inside all nice and climate controlled and the sender is screwed into the water jacket all secure and not moving around. Not that they don't go bad, it's just I usually end up replacing and rerouting the wire.
ambainb
Apr 25, 2016 09:21 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
