Have power, but no crank..any help
Old Oct 14, 2006 | 11:08 PM
kenf729's Avatar
Car: 1989 Camaro RS, 355, holley 650dp
Engine: flow master headers, 3" exhaust
Axle/Gears: stock
Ok, here goes, bought this 89rs no engine or tranny, re-built a carbed 350 (stock) 700R4 tranny, finally got it in the car, hooked up as much of the electronics as possable (alt, starter, HEI dist). have power to the key, heater, wipers, lights everything works, but it won't crank.
Now, I turned the key on, jumped the starter to crank and it fired right up and ran for a few sec's, had to shut down due to my error, I forgot to put in the oil pressure sensor...my bad...oil over every thing..hehe...
Any way, any ideas why the car won't crank? new to this car and the key chip thing...
Ken
Old Oct 15, 2006 | 02:35 PM
kenf729's Avatar
Axle/Gears: stock
Any body???
Old Oct 19, 2006 | 08:20 AM
teamstream's Avatar
Car: 91 Purple Z28
Engine: 5.7 TPI
Transmission: 700 R4
are you using the factory harness? how many wires do you have to the starter? suppose to be 3 i believe. you might need a older harness....or could possibly be the chip in the key..but im not sure..buddy of mine converted his 89 v6 camaro to V8 and didnt have that issue and it has the chip in the key.
Old Oct 19, 2006 | 10:24 AM
kenf729's Avatar
Axle/Gears: stock
Yes still using the stock harness, 3 wires to the starter. and have the chip in the key also. my thought was to check the continutity in the wires, I was reading that there is a in line fuse, maybe not good?
Old Oct 19, 2006 | 12:09 PM
teamstream's Avatar
Car: 91 Purple Z28
Engine: 5.7 TPI
not sure if there is a fuse...unless one under the dash is bad? one wire to the starter is from the battery, other 2 off the harness....right? i guess check to see if there is voltage to the harness wires to the starter.
Old Oct 19, 2006 | 12:52 PM
kenf729's Avatar
Axle/Gears: stock
I'm thinking the one wire on the "S" side of the starter is the one going to the ignition, that one has one of those big inline fuses, maybe that one is bad? I'll just have to check. the previous owner had some pretty creative wiring going on, unfortantlly I removed all prior to checking what they did...
Old Oct 30, 2006 | 09:11 PM
foolforspeed's Avatar
Car: 1989 camero rs
Engine: 305 tbi
Axle/Gears: not sure
My 89rs did the same thing. if you have a chip on your key then you have theftlock system. I had to sned mine to the dealer and they changed the ignition. they said when the ignition wears out that this would happen. if you changed out the motor its possible that you did something to trip the theftlock system. call gm service dept for advice. good luck !
Old Oct 30, 2006 | 09:24 PM
Car: 1989 camero rs
Engine: 305 tbi
theres an article about theftlock in the tech dept
Old Oct 31, 2006 | 11:45 AM
kenf729's Avatar
Axle/Gears: stock
Ok, so if I've disconnected the ECM, what effect would the Chip have? also I'll do some more reading in the Tech dept....thanks
Old Oct 31, 2006 | 05:22 PM
83z28camaro's Avatar
Car: '01 GMC Sierra
Engine: 5.3L
Transmission: 4L60e
Axle/Gears: 3.73 eaton locker
starter disable relay. It is behind the left kickpanel behind some black stickey paper. connect the big wires together. they should be yellow and purple or green.
Old Nov 1, 2006 | 02:02 PM
kenf729's Avatar
Axle/Gears: stock
thanks I'll take a look tonight, just disconnect the relay and connect the big wires and it should work? thanks again.
Ken
Old Nov 1, 2006 | 03:26 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
[QUOTE=83z28camaro;3112193]starter disable relay. It is behind the left kickpanel behind some black stickey paper. /QUOTE]
(start enable relay) number on it is 14093107. Please dont cut your wiring. Pop the cap off and inspect the coil. It may be corroded or the fine copper wire may be broken. If no visable sign, test it with your ohm meter for continuity. If bad, replace the relay.
Old Nov 1, 2006 | 03:51 PM
kenf729's Avatar
Axle/Gears: stock
I'll take a look tonight I wasn't planing on cutting wires, to test I thought about just jumping them, if the relay is shot I'll pick up another. just as long as it isn't used in conjunction with the ECM.
Old Nov 1, 2006 | 07:37 PM
'86 350's Avatar
Car: '86 Camaro SC
If you don't mind me asking, how'd you jump the starter? I'm having a similiar problem on my car.
Old Nov 2, 2006 | 08:35 PM
Black85sport's Avatar
Car: 91 Silverado
Engine: 350 TBI, EBL Tuned
Do you have power at the starter solenoid?
You can change your ignition cylinder with a cheapie one (i.e. standard ignition brand) that doesn't use a chip in the key. Just install a resistor
Old Nov 2, 2006 | 10:27 PM
kenf729's Avatar
Axle/Gears: stock
I just attached a wire to the S side of the starter and touch it to the positive side of the battery, naturally I have the key turned to the on position.
thats my next step, I need to get someone to turn the key while I'm under the car testing power to the starter..
Old Nov 4, 2006 | 07:24 PM
'86 350's Avatar
Car: '86 Camaro SC
I'm assuming by "S" side you mean the solenoid side of the starter? So I should just attatch a wire to post on the starter closest to the solenoid and then jump it?
Old Nov 5, 2006 | 03:47 PM
kenf729's Avatar
Axle/Gears: stock
Yes, on the solenoid you'll see one of the posts has an "S" attach a wire to that and hit it against the + side of the battery, the engine will turn over. no if you have the Key on and have power going to the Distrubitor it should fire right up... hope this helps
Ken
Old Nov 8, 2006 | 05:11 PM
LemurRS92's Avatar
Car: 1992 RS Camaro
Engine: 305 TBI
I had the same problem of no juice to the starter but all the lights work. It would happen 1 out of every 30 starts or so. I took apart the ignition switch and found a slight worn spot and burnt dried grease. I tried cleaning it it worked for awhile then i replaced the whole switch.
Old Nov 8, 2006 | 10:36 PM
kenf729's Avatar
Axle/Gears: stock
So just wondering, if you changed the switch, I take it you've taken out the ECM since you didn't state anything about the chip in the key? I wonder if my switch is bad?? thanks
Old Nov 10, 2006 | 03:58 AM
Wi$h's Avatar
Car: 91' Z28
Transmission: 700r-4
the ignition switch is a likely suspect, but before you go replacing things check to see if you have power to the s terminal on your starter while the key is in the start position. if so then go to ignition switch but before you go and replace it test that as well, test it in the start position and see if you have 12v coming out of it. if you don't then its your ignition switch.
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
