82 ecm wire pics
Old Apr 25, 2007 | 07:00 PM
carls1982z's Avatar
Car: 1982,Z/28
Engine: 355
Transmission: t350
82 ecm wire pics
i need wiring pics of the conn"s at the 1982 crossfire ecm, as im looking too hook up my wide ban 02 sensor from zeitronics. too my 7747/and ham/prominator
Old Apr 25, 2007 | 10:21 PM
82CrossFire Z28's Avatar
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
Re: 82 ecm wire pics
Carl
I will post a scan of the terminal connection diagram for the 82 Camaro from the service diagram. It may be a day or two, as I need to reconnect my scanner to my computer
Dave
Old Apr 26, 2007 | 12:35 AM
Carl
Got the scanner hooked up, so here is the diagram. Note that the high side of the O2 sensor is a PPL (Purple) wire connected to terminal 8 of the BLACK I/O connector (on the bottom of the diagram) and the O2 ground connection is a TAN wire connected to terminal 15 of the BLACK I/O connector.
If you need the other wire colors, let me know.
I suggest you right click on the image below and "Save Link As" to your computer. Then open the file in some picture viewer software so you can rotate and zoom in to read them.
Good Luck with your project
Dave
Attached Thumbnails 82 ecm wire pics-82-camaro-ecm-cf
Old Apr 26, 2007 | 06:15 PM
carls1982z's Avatar
Car: 1982,Z/28
Engine: 355
Transmission: t350
thanks there, 82 crossfire
Old Apr 26, 2007 | 06:48 PM
carls1982z's Avatar
Car: 1982,Z/28
Engine: 355
Transmission: t350
Sounds like you wired up for a simulated narrow band there.----am i correct ---with that purple wire
Old Apr 26, 2007 | 11:50 PM
I am not sure However, I still have the original, stock O2 sensor. So if that is "narrow band" then yes that is what I have. The wire color is from the service manual. By the way, as soon as I can pdf it, I will post a connection chart with all the circuit numbers, wire colors and circuit descriptions for the 82 CrossFire ECM connectors.
I am curious. Did you replace your ECM and if so, does the replacement ECM control the air induction hood flaps . The hood flaps are controled by the original ECM.
Dave
Old Apr 27, 2007 | 08:38 AM
carls1982z's Avatar
Car: 1982,Z/28
Engine: 355
Transmission: t350
YES, I have replaced the ecm.---it now has 7747 ecm out of 90 -91 truck . along with the prominator in it. as i had too upgrade so as i can tune for the mods i did too veh.-----the hood flaps were suppose too work as they put in driver ? for it too oper.----when they put prominator in pcm,-- but mine doesnt.--- i think they goofed when i ordered it. doesnt matter tho as i keep it open manually all the time.
Old Apr 27, 2007 | 12:42 PM
Sorry to hear that the flaps don't seem to function with your new equipment. If you want to trouble shoot it a bit, I can post the diagnostic chart for the hood flaps from the service manual.
Attached in the pdf file is the complete ECM pin out, with wire colors, circuit numbers and signal descriptions.... enjoy or keep for your future reference
File Type: pdf
89GTAOz
May 16, 2020 09:31 AM
Jae992
Aug 27, 2015 09:07 AM
djmarch
Aug 19, 2015 12:07 PM
stalkier
Aug 13, 2015 12:59 PM
marcusaw
Aug 10, 2015 08:13 AM
