Temperature Gauge and Oil Pressure Gauge
Old Aug 25, 2007 | 12:40 AM
geehumshriber's Avatar
Now, I believe that the oil pressure sender is located just to the right of the distributor when looking into the engine bay from the front hear the driver side valve cover, where is the wire that connects to this "canister" so I can hook this up? I need to know where it is before I start to clean up my wiring. What colour is the wire, or the clip that attaches to this part?
Secondly, how does the temperature gauge function? Where do the wires all connect to send the signal to the cluster? I do not get a reading, and I just replaced the thermostat and gasket but I still don't get a reading. Now the piece that bolts on over top of the thermostat has a large tube running to the radiator and two other mounts (one has two small pipe fixtures and one as a larger fixture). Am I looking at the correct place? Where is all of this located?
Any pictures are appreciated, I am indeed a visual learner.
Thanks for all of your input.
G
EDIT: 82 Camaro with 5.0L Carbed non-CCC
Old Aug 25, 2007 | 12:59 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Temperature Gauge and Oil Pressure Gauge
The sender for the temperature gauge is in the driver side head. It has a single wire to it.
Old Aug 25, 2007 | 01:00 AM
I was just outside a couple minutes ago and I didn't see any wiring running off of the driver side head, where would the wire have gone? Does it run off a group of wires?
Old Aug 25, 2007 | 01:04 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The sender wires for both senders disappear into the wiring harness attached to the bulkhead connector on the drivers side.
Old Aug 25, 2007 | 01:11 AM
It's not connected, I'll have to hunt out the connections or at least take a pictures of what's going on. What style of connectors are for the temp gage and what color wire is for the oil pressure?
Old Aug 25, 2007 | 01:13 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I don't know the colors offhand. Both connectors have a single blade type terminal, although the coolant temperature could have a button terminal instead.
Old Aug 25, 2007 | 01:14 AM
Looking at the poor quality Autozones suggest that the temperature is a button. I'm a color guy, so that'll help me most. I'll keep hunting.
Old Aug 25, 2007 | 01:37 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
on my 87 its a green wire...
Old Aug 25, 2007 | 01:39 AM
83Chevy__Camaro's Avatar
the head temp sensor is a green wire, need to get yourself a shop manual, my 83 book has color coded section showing all wires
Old Aug 25, 2007 | 01:43 AM
I have an 86 Firebird manual, and I've had a few Haynes manuals for other cars but I've found them to be useless for what I'm doing. Shop manual for an 82 is hard to come by.
Old Aug 25, 2007 | 02:00 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
http://www.helminc.com
Old Aug 25, 2007 | 12:37 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Temp gauge wire is green in 86 as well.
Old Aug 25, 2007 | 01:51 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
Oil is probably tan or brown.
Old Aug 26, 2007 | 11:05 PM
Yes indeed, the temp wire is green, and the oil is tan. For some reason on the harness the temp wire had a flat clip which was supposed to attach to a button (someone please explain this?) so I'll find a clip and attach. As for the oil, still on the hunt for the last wire!!!
Old Aug 27, 2007 | 12:37 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The flat clip slides on the button from the side. GM abandoned the button at some point, and replacement senders come with a single spade terminal.
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
