Blinkers not working, any ideas?
Old Jan 7, 2008 | 04:03 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
They were but now they just stopped, is there a common problem i might not know if? It is on my 89 and yea, all the fuses are good i have checked them and double checked them. I hope to get them fixed before i actually get pulled over!
Thanks for any help.
Old Jan 7, 2008 | 04:04 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: Blinkers not working, any ideas?
the flasher unit for the blinkers...do your fourways work???
Old Jan 7, 2008 | 05:07 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
My emergency lights? I dont have the button for them, i have to take the button off my 85 TA and see if it works. The flasher unit is in the colum i am sure right?
Old Jan 7, 2008 | 05:38 PM
84redta's Avatar
yea it should be in the column. If they work then my guess is wrong...but it may be your flasher unit. Confirm if the 4way emergency flashers work or not and we can go from there.
Old Jan 7, 2008 | 11:58 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Alright, ill check it later today.
Old Jan 8, 2008 | 01:08 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
also make sure ALL the light bulbs that blink are seated properly in the socket. For 20yr old cars, the connections aren't as tight. I thought my left flasher wasn't working either but I checked all the bulbs in the tailights and the front turn signals and its fixed now...
Old Jan 8, 2008 | 05:42 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Nope, nothing at all, no emergency lights ither....
Old Jan 8, 2008 | 07:24 PM
84redta's Avatar
my guess is the flasher unit, i believe it is located in the "convenience center." Look under the dash and notice a cover for the plug that GM uses to read your car codes. Above that is the flasher unit. You need to lower the entire unit. You may need to lower the hush panel on the driver side. I believe the entire thing is held in by two screws. All should be 7MM. Pull it down and you will see this round cylinder looking thing, pull it out and there are only two prongs IIRC. Bring that to your local automobile store and they should be able to hook you up with the flasher unit that you need. If i'm wrong on any of this someone chime in, but that would be my opinion/suggestion. If you have a 7mm socket wrench you might be able to do all this at the auto parts store so that you don't need to drive around with hanging wires which may be dangerous. Be careful and good luck!
If at all possible...get a volt meter. After you take eveyrthing apart, unplug the flasher unit, and then turn on your turn signal and test one of the two leads of the flasher unit. Make sure that you have power to the flasher unit. If you don't have power it may be a totally differnt thing.
Old Jan 8, 2008 | 08:47 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
I am also trying to remember if it started after i removed that annoying buzzer for the key. Ill check it out motr tomorrow, thanks for the help, ill keep you posted.
Old Jan 8, 2008 | 08:49 PM
84redta's Avatar
yea you can try putting back in the buzzer and see if it works. Keep us posted and we can go from there, but if you uninstalled something, put it back and we can go from there.
CarGuyDennis
137
Dec 6, 2016 11:02 PM
perZ
Aug 15, 2015 01:17 PM
stalkier
Aug 13, 2015 12:59 PM
dhonda200
Aug 11, 2015 11:50 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
