toggle switch?
Old Feb 5, 2008 | 06:26 PM
blkcam's Avatar
toggle switch?
i just got a 91 rs like 1 week ago. i was looking at the fusebox and to the right of it is a toggle switch. does any one know what this is for?
Old Feb 5, 2008 | 06:33 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: toggle switch?
to my knowledge there are no toggle switches provided by GM...it's very likely aftermarket. It's prob for neons or something of that sort, or aftermarket security system. Trace the wires are the only way to figure it out. It's right there because it's close to a power supply, so one of the wires will go to the fuse block...you need to trace the wires going the other way to see where they lead...the previous owner may have already removed w/e it was before selling it to you.
Old Feb 5, 2008 | 07:32 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Re: toggle switch?
It's a valet switch for an alarm.
Old Feb 5, 2008 | 07:49 PM
blkcam's Avatar
Re: toggle switch?
thanks man
Old Feb 5, 2008 | 07:50 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: toggle switch?
could be a starter or fuel pump kill also, some peeps did this for a insurance discount
Old Feb 5, 2008 | 07:55 PM
84redta's Avatar
Re: toggle switch?
insurance discount wuh!?!?! pm me with details, lol.
Old Feb 5, 2008 | 08:17 PM
blkcam's Avatar
Re: toggle switch?
ya, wat u mean insurence discount??? because i havent been able to start the car yet also
Old Feb 5, 2008 | 08:23 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Re: toggle switch?
Spell check is a good thing
Old Feb 5, 2008 | 08:51 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Re: toggle switch?
HAHA!
Very true.
I also have never heard of having an insurance break for having a toggle switch connected to my fuel pump.?
Old Feb 5, 2008 | 08:53 PM
blkcam's Avatar
Re: toggle switch?
Ill clarify for you. He said there's an insurance discount if the car has a switch for the starter or fuel pump. I was curious if my switch is for the starter or fuel pump because I have not been able to start the car yet.
Old Feb 5, 2008 | 08:59 PM
Re: toggle switch?
ok,so if I were to go out to the garage and hack a couple of wires and add a toggle switch in the mix,I would get cheaper insurance on my car?
Old Feb 5, 2008 | 09:05 PM
blkcam's Avatar
Re: toggle switch?
I don't know lol, look at what 89RS_82Z said.
Old Feb 5, 2008 | 09:36 PM
Re: toggle switch?
yeah,I already did.
That just doesn't make sense to me though.
Old Feb 5, 2008 | 09:40 PM
84redta's Avatar
Re: toggle switch?
lol, idk, i got no response, and 89RS_82Z, just so you know we're not making fun just so you know we are looking for any potential savings possible . So if you know anything please enlighten us so we can check if it's available. Back to issue at hand. When you turn the key do you hear the fuel pump engage? When you turn the key does your starter turn? If both don't do anything then you got a bigger problem. If that switch has a lead going to the fuse panel then i don't see how it's for starter or fuel pump, and if you get dash lights and the little security light on...have fun with VATS...thats all i'll say about that one, lol.
Old Feb 5, 2008 | 09:41 PM
blkcam's Avatar
Re: toggle switch?
yeah,I already did.
The insurance companies probabley think of it as an anti theft device.
Old Feb 5, 2008 | 09:42 PM
Aaron_SK's Avatar
Car: 1985 Sport Coupe
Engine: 3800 Series II Turbo
Transmission: 4th-gen WC T5
Axle/Gears: 3.27 BW Limited
Re: toggle switch?
Some insurance offer discounts for alarm and disable systems if you are buying comprehensive.
As for this issue, assuming you tried starting the car with the switch both ways, trace out the wiring. It will most likely go to an alarm module under the dash or kick panel.
If the car has an alarm, find the bundle of wires going down the column and carefully pull them apart till you find a fat yellow (or possibly purple) wire. You will know it because it is the biggest one. Somewhere they will probably have cut it and installed something inline. Just join the wire back together to bypass the alarm or starter kill.
Old Feb 5, 2008 | 09:47 PM
blkcam's Avatar
Re: toggle switch?
I am going to try to start it again maybe tomorrow or sometime this week with a new battery, because the old battery that is on there now is dead. When I hooked it up after I recharged it, the interior lights turn on but the starter struggled and the engine did not turn over. I did not check for the security light. Hopefully it is just the battery.
Old Feb 5, 2008 | 09:59 PM
kcb37's Avatar
Re: toggle switch?
It kinda make sense that you could save on insurance. If you got in a wreck, so long as you were still concious you could shut the pump off. Less likely for the car to explode. Course turning the key off does the same thing.
I am going to put one on my ignition, (instant kill), and one on my fuel, (explosion thing). I am only doing this cause I am going to drag race my car. That way you can kill it and still steer.
Side note,
It's also a poor man's theft control.
Old Feb 6, 2008 | 11:50 AM
89RS_82Z's Avatar
Re: toggle switch?
yea i been away, sorry guys!!!!!!!!!!
i was told about the idea along time ago, you put a switch inline with the power to the relay for the fuel pump or starter, flip it off when you leave your car......some punk tries to steal it (even with keys) and it wont strat, he i going to say "blank it" and find something else, its like a poor mans VATS system, my neighbor had one on his jeep, what you do is tell your insurance company you have a strater disable, you want the switch in a easy to fip on and off but hard to find area (ie under the dash behind the fuse pannel)
Old Feb 6, 2008 | 12:04 PM
84redta's Avatar
Re: toggle switch?
i gotta try that with my insurance company...would be nice to get as much savings as possible, lol. I'll ask ?s b4 i go cutting and splicing tho. Thanks!
Old Feb 6, 2008 | 12:19 PM
89RS_82Z's Avatar
Re: toggle switch?
yea i save alot since i have a full alarm with a starter disable in the alarm, and then the vats, plus car is kept in a garage helps to
Old Feb 6, 2008 | 04:42 PM
Aaron_SK's Avatar
Re: toggle switch?
No, what he's (or she's, gotta be PC) gonna do is start digging under the dash for the switch. Now if you place the switch somewhere other than under the dash (as I have) they will still eventually find the wire, but this costs them precious time.
The bottom line is that you cannot stop any car thief. Any skilled thief with an infinite amount of time can steal any car. Their biggest enemy is time. Any system you install (fuel kill, starter kill, alarm, gps, club, whatever) will only slow them down. But for every minute you can slow them down, you increase the likelyhood that they will be noticed and your car will be saved.
Right now I have my starter on kill, I would have put my fuel pump on a kill but I've got a new idea for that. I'm going to try and make a timed kill for the pump. With the switch off current to the pump is routed through a time release switch that flips after 15 seconds, then reverts.
How long do you think they will want to drive in a car that dies every 15 seconds?
Old Feb 6, 2008 | 07:21 PM
Re: toggle switch?
yeah,or in your case an anti run device.
Who knows what the previous owner did to your car.
Have you found anything yet on the column as far as alarm wiring?
I have seen alot of crazy ideas for alarms/anti theft gadgets .
So if you haven't got it running yet,lets have some pics and get to the bottom of this.
Old Feb 6, 2008 | 08:10 PM
blkcam's Avatar
Re: toggle switch?
I have not gotten a chance to take the column apart to check the wiring. Maybe by the end of this week ill take it apart and post up some pics of the wiring and the switch. But I got a bad feeling the reason the car wont start is because of the VATS. I also have another question, my steering wheel moves downward when you pull down on it, why is this? and how do I fix it?
Old Feb 6, 2008 | 08:53 PM
Re: toggle switch?
you shouldn't have to take the column apart to check for alarm wires.They should be visible from just looking under the dash.
Does your car have tilt steering?
Old Feb 7, 2008 | 03:38 PM
blkcam's Avatar
Re: toggle switch?
it does have tilt steering and at any position i put the steering wheel, it still moves when you pull it. i might check later on for the alarm wires
never mind, i just found an article about the wheel moving. http://www.gnttype.org/techarea/susp..._steering.html
Veaceonee
Sep 29, 2016 08:15 PM
MSRed91Camaro
Oct 6, 2015 01:56 PM
RacerM
Sep 28, 2015 04:25 PM
327IROC85
Sep 23, 2015 12:11 AM
Randomtask2
Sep 10, 2015 08:37 AM
