88 GTA Headlight problem...
Old Oct 16, 2008 | 08:21 PM
LagunaSeca's Avatar
I have a 1988 Trans Am GTA and the driver side headlight is acting weird. It takes longer for it to come up than the passenger side and it hesitates when coming up. The motor doesn't hesitate, but the light does. But here is what im worried about, Even after the light is up or down the motor still runs for another 7-8 seconds. what the hell is wrong???
Old Oct 16, 2008 | 08:47 PM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
Re: 88 GTA Headlight problem...
Sounds like the bushing are dust....
R & R them
Old Oct 16, 2008 | 09:05 PM
LagunaSeca's Avatar
would the bushings being dust make the motor run even after the lamp is already down? thanks alot for your help to.
Old Oct 16, 2008 | 09:15 PM
LagunaSeca's Avatar
I forgot to add to that when I have just the parking lights on, then turn them off the same light motor also turns on for some reason for about 5 sec....
Old Oct 16, 2008 | 09:29 PM
72vega's Avatar
Car: 2008 Silverado, 73 LeMans, 1987 GTA
Engine: 4.8, 350 Pontiac, 350 LT1
Transmission: 4L65E, TH350, T56
Axle/Gears: 3.42, 2.73, 3.42
http://www.top-downsolutions.com/pro...products_id=87
Old Oct 16, 2008 | 10:08 PM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
Yes... I even a lazy headlight.
I when to the local hardware store and bought the bushings (plastic spacer)
For $3 for a pair of them. You will need 3 for each side or buy longer ones and cut them in half for an extra $.50 I used a file to make them even with the motor. My Corvette has this problem first. Then my 90 Firebird has the problem....
Old Oct 20, 2008 | 12:16 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Yes.
The repair kit I sell fixes both symptoms you describe.
Lon Salgren
Old Oct 20, 2008 | 06:41 AM
Steveh4263's Avatar
Car: 1987 Pontiac Trans AM GTA
Engine: 5.7 LTR
Transmission: Automatic
I used the TPS kit and it worked really well on my 87 GTA. Very Detailed Instructions on how to fix the headlights with the 3 bushings on each headlight motor. The drivers side is harder to do than the passenger side though.
Veaceonee
Sep 29, 2016 08:15 PM
nova983
European Region
Nov 2, 2015 12:15 PM
Isaac McCormick
Sep 12, 2015 10:20 PM
sylentnite
Sep 9, 2015 02:55 PM
luvofjah
Sep 3, 2015 07:08 PM
