Battery voltage drop?!?!
Old Apr 13, 2009 | 10:18 PM
3rdGenIrocZ's Avatar
So me and my grandpa (macanic) had to re-wire the fuel pump so it works and as doing so we wired up my outlets in my 4th gen console( 2 outlets) Before the pump was rewired i would run anywere between 12-16 amps or volts which ever the gauge reads. And now after driving it after the rewireing im at 8 on the guage. after driving for about 30 minutes i was under the red and my dash was barely visable, my head/tail lights were basically out. the radio wasnt even turned on from the massive drop. Any clue how to get power back? im recharging it but that isnt worth it cause it was charging for awhile yesterday
Old Apr 15, 2009 | 12:21 PM
Re: Battery voltage drop?!?!
Honestly? not even a single person can tell me. thanks
Old Apr 15, 2009 | 10:27 PM
RockJay81's Avatar
Car: 84 Z28......99 TA
Engine: Lq9 6.0... Ls1
Transmission: 4L60E X's 2
Axle/Gears: 3.73 on both
check your grounds and you may have a short. also check the alternator might be on its last leg
Old Apr 15, 2009 | 10:52 PM
i just got a new battery about 6 months ago and a new alternators about a year ago. before i start the engine the gauge reads 14 and then i start it and its right at 8. i dont want to drive it because it will basically die.
Old Apr 15, 2009 | 11:07 PM
Awesome-X's Avatar
Car: 87 Camaro
Take the alternator to a parts store and have it tested. Parts like to go bad at really inconvenient times, like when you're working on an entirely different part of the car, so then you think its what you were working on.
Old Apr 15, 2009 | 11:10 PM
ok ill take it to autozone tomorrow. if nothing is wrong with it do you think it could be because we wired up 2 outlets? just to cig lighters used for charging phones if needed. so most of the time they arent being used
Old Apr 18, 2009 | 06:54 PM
macertheracer's Avatar
Car: '91 RS CP now is the son's driver
Engine: CP =3.1, will get V-8 maybe someday
Transmission: stock
Axle/Gears: 3.42 posi W/ disks
did you find your problem,, if not check your fusable links at the starter, sounds to me like you shorted something and blew a link. that is the only reason I can come up with. the alternator will not put out a charge if is does not detect a power system (ie the battery) and all of the power to the alternator starts at the battery to the starter then on into the system. try running a jumper from the battery + (positive post) to the Alternator see if that gets things on track, if so get under the car and find out which link is bad
Old Apr 18, 2009 | 07:00 PM
Awesome-X's Avatar
Car: 87 Camaro
Yeah actually fuse links are a good suggestion, I had a taurus I thought the alternator was out on so I changed it but it turned out it was the link that sits on the side of the fuse box.
Old Apr 18, 2009 | 11:33 PM
any1 got a pic for this link? i got my alternator checked and it was running great
Old Apr 18, 2009 | 11:44 PM
Transmission: stock
no i don't, but you can find it easy enough. get to your starter there is some 10 guage wires, 2 or 3 "connected along with the battery cable" give each of them a little tug if one or more seem to stretch and spring back you have found your problem
Old Apr 18, 2009 | 11:53 PM
ok and would an MSD hekp alot of i instal one?
Old Apr 20, 2009 | 09:08 PM
ClickClickVroom's Avatar
Car: 92 Z03 RS TBI
Engine: 5.0 L03
It has nothing to do with your currrent situation. Check the little power distributor (not sure of technical name) by the battery. If you're facing the car it's to the right of the battery. Make sure that nut is really tight.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MM2Robinson
Oct 1, 2017 09:16 AM
Johnoooooo
Sep 22, 2015 08:55 AM
eustodp
Sep 20, 2015 05:09 PM
Formula_88AE
Sep 3, 2015 01:47 PM
