Speedometer issues....
Old May 24, 2009 | 02:45 PM
coryprine's Avatar
Car: 85 Camaro Z28
Engine: 5.7 TPI
Ok im not sure if this is the right section so mods move it if incorrect please..... I have an 86 Camaro IROC bone stock.... has the stock 16 inch wheels with the proper tire size, however my speedo is wayy off.... It will read 55 when im actually going 45 and so on... Me being a cop, a ticket isnt really the issue... The issue is that I am **** about everything working properly... Do I just need to change out the speedo in the cluster or is there another issue at hand?... Thanks a ton for any help!!
Old May 24, 2009 | 03:27 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Speedometer issues....
The following link should provide food for thought:
https://www.thirdgen.org/forums/inte...eedo-woes.html
JamesC
Old May 24, 2009 | 06:03 PM
JTNKTZ's Avatar
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
"Me being a cop, a ticket isnt really the issue..."
What exactly makes you an exemption to the law? I am a little lost... I don't mean to come off as offensive but that's just not the way you should think, you are no different then everyone else, hence a Democracy, all people are created equal.
Old May 24, 2009 | 10:46 PM
coryprine's Avatar
Car: 85 Camaro Z28
Engine: 5.7 TPI
all i am saying is that is very unlikely to recieve a citation due to the fact that the car never leaves my patrol area, hence unlikely to get a ticket from one of my own...
Old May 25, 2009 | 08:33 PM
JTNKTZ's Avatar
Engine: 355/350
In other words, be exempt from everyone else because you are a Police Officer in your "area"....
Old May 25, 2009 | 08:52 PM
JamesC's Avatar
JamesC
Old May 25, 2009 | 10:39 PM
coryprine's Avatar
Car: 85 Camaro Z28
Engine: 5.7 TPI
oh my driving habits werent the question at hand so if ya dont have nething helpful please dont say anything at all... k?... thanks
Old May 26, 2009 | 01:59 PM
JTNKTZ's Avatar
Engine: 355/350
When did this happen? Did you buy it like that or did it just start one day?If it just happened then what were you doing when it occured? I think the best place to start is a new speed sensor mechanism that is attached to the transmission with a big cable plugged into it.
http://store.summitracing.com/partde...5&autoview=sku
WARNING: This may or may not be the right drive gear but Summit does say it is for a 1986 Camaro. I would research more on that.
The one on your car, which is bone stock, is mechanical unlike the 90+ models that have a VSS (Vehicle Speed Sensor). If it is not that the next step would be the actual speedometer, unless the drive gear on the speedometer gear housing is stripped/broken.
Old May 26, 2009 | 05:05 PM
coryprine's Avatar
Car: 85 Camaro Z28
Engine: 5.7 TPI
hmm is that piece from summit hard to install?... never done one before and i didnt know if it was a simple bolt on item or does the tranny have to be dropped or anything...
Old May 26, 2009 | 05:20 PM
JamesC's Avatar
That application is for a TH400, I think.
JamesC
Old May 26, 2009 | 07:59 PM
JTNKTZ's Avatar
Engine: 355/350
He's right but I would call to ask if it would work because I found that searching in the 1986 Camaro category...
JamesC
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
