Battery Relocation - Wiring....LOTS of pics
Old Sep 6, 2009 | 10:18 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
Take a look, see what you think and let me know if there is anything you think might cause a problem. I'm having a few gremlins I'm trying to iron out.
Wiring at battery:
+ 1/0 Welding Cable from battery to kill switch
+ 4 ga Alternator charging lead from alt to battery
- 1/0 welding cable from battery to frame
- 4 ga directly from the head to the battery
Let's look at my grounds.
GND at head directly to battery:
Old Sep 6, 2009 | 10:21 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Re: Battery Relocation - Wiring....LOTS of pics
GND at frame in rear of car from battery:
4 ga GND strap from head to frame of car in engine bay:
NOTE: The smaller black cable runs to a GND distro block in the nose of the car...
Old Sep 6, 2009 | 10:23 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Even have the alt grounded directly to the head:
So, that takes care of the grounds, lets look at the hot wires.
1/0 Welding cable runs from the kill switch up to this distribution block:
The power distribution wires run directly to here now, not the starter. Wanted to keep them from frying.
Old Sep 6, 2009 | 10:24 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
1/0 Welding cable runs from the distro block to the starter:
2 ga battery cable runs from the starter to this distro block to power the fan and soon, MSD box:
4 ga alt charging lead directly to battery:
So...what's the opinion? Anyone see anything that could cause a potential problems??
Old Sep 6, 2009 | 10:27 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Marine terminals....so easy when you always work on the electrical system:
Kill switch location:
Old Sep 6, 2009 | 10:31 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
nice. and clean looking.
Old Sep 6, 2009 | 12:47 PM
punkdude908's Avatar
Car: 1983 Pontiac Firebird
Engine: LG4 305ci 4bbl
Axle/Gears: 10-bolt open diff.
looks good but i see one issue- that looks like a regular wet cell battery, which vents hydrogen gas. where you have it now will vent the hydrogen gas into the passenger compartment.
there are 2 ways to get around this- either run a sealed vent from the battery box to the outside of the car, or get an absorbed glass mat (or AGM, like Optima) battery because those do not vent.
Old Sep 6, 2009 | 01:53 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
While I usually run Optima, this battery is a temp. The box is sealed and vented outside the car. I still need to drill two more holes and get some more grommets for the GND and alt charging lead. It's actually an aluminum box too, just has that protective vinyl still on it...
Old Sep 7, 2009 | 12:50 AM
ok good! just wanted to make sure you had all that. looks good- nice, clean install.
Old Sep 11, 2010 | 11:54 AM
Blownz28man's Avatar
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
Couldn't you of just when from alternator to starter for the charging lead? Your starter wire would carry the voltage back to the battery right? i'm getting to relocated and want to run as little wires as possible. But good write up!
Old Sep 11, 2010 | 12:09 PM
ZimGTA's Avatar
Car: 88 GTA
Engine: 383
Transmission: 700 r
Will the main distribution block handle enough amps to turn the starter?
Old Sep 11, 2010 | 12:38 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Yes, but with it hooked up that way the kill switch would be rendered useless. If you do not run a kill switch (which I don't recommend) that would suffice.
Certainly, its just a hunk of metal.
Old Nov 25, 2010 | 03:13 AM
chevysurfer's Avatar
Car: 91 CAMARO RS
Engine: 305 TBI
Transmission: AUTOMATIC
I am about to wire up my battery in the trunk. I want to put it where you did so I dont lose my spare tire. That looks really good I saved this and will be using it as a reference. But what are the gremlins that you are having? So I know what to look for. Also I have many junction boxs, big inline fuses from previous high amp installs,(600-1200)amps. Im getting hung up on the power flow from alt, battery, starter. And how to use my junction boxs to simplify things and where on the flow to place them. Also I read somewhere to put a big fuse on the power wire going to battery?
Old Nov 25, 2010 | 11:59 AM
DAVECS1's Avatar
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
Your setup looks fine. I have a couple of suggestions, thats all they are so take them for what they are worth.
First I would put the Kill switch on the GND side of the battery. Accidental live switch failure modes are a little better. If the starter gets stuck and someone switches that switch there is lwss potential for the leads to weld to the switch housing and melt it.
Next, I would measure resistance from the - battery to each of your GND landing points. With the thirdgen being unibody, it is not always garanteed that continuity is had throught the subframe and chassis. Should never see over 1 ohm.
Next, If you can scavange or afford it. Get rid of the audio equipment stuff. It is not rated for that enviroment and you will need to keep an eye on it. The welding cable is good but keep it away from chemicals and sun light. What you really need is SGX battery cable and SXL wiring. This is very robust for auto and industrial enviroments. The only thing it will take offense to is extreme amounts of ATF and hydraulic fluid, but it is more tolerant than most.
Next are the junction blocks they should work, but screw terminals are less than desirable, in heavy duty applications Copper relaxes after time, so if not properly crimped or soldered the connection will weaken. Your best bet is lug and gland/ ring terminals, the more expensive solution would be connectors from Duestsch or Tyco. You can get most of these parts from a heavy equipment supplier like CAT or Deere. As for junction blocks, the heavy equipment pieces would be good. I have also score some real nice stuff off of heavy duty trucks in Junk yards.
Las but not least. I like those battery terminals you used. The copper ring terminals are just about as good as it gets. The way I put them on is with my plumbing gear. Flux them, heat them up with the propane torch and then fill the ring terminal with solder and insert the wire. If your using SGX wire the insulation will be fine. Then I use adhesive lined heat shrink as electrical tape is not heat or chemical friendly.
I design equipment that runs in the Oil Sands of Alaska, and failures are few and far between. I also happen to be a gear head and my hot rods do not have electrical problems
Old Nov 25, 2010 | 09:18 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Thanks Dave, see the red.
I have heard this many times and never really thought about doing it myself. Seems much safer and more efficient but, at this point, I would be too short on my power lead and would need another section of 15 ft. 1/0 cable.
I do wish I could do the entire rig over with the knowledge I have now, however.
Everything seemed to ohm out well but for good measure I did run a 4 ga ground directly from the head to the battery. I just don't trust the chassis at all!
Also one of those thing I wish I could do over again. The audio wire was definitely what I had laying around but, luckily, everything is our of contact with pretty much any element as I know its not the most durable.
I always had previously thought the welding wire the best you can get and that's why I went with it for the main power and ground leads.
The junction blocks are definitely the cheap brands but I was unaware this would make a huge difference. I guess when I originally executed this plan I didn't do enough research and plan for the long term. Do you see a big problem with what I have?
Thank you, I crimped and soldered the lugs and sure hope they can withstand my abuse but, once again, I wish I could do everything over again (like the entire car!!!) and do everything 100% correct.
I appreciate the time you took to analyze the setup, everything said is taken graciously and very much appreciated. Hopefully in the future I can chip away at some of the more problem areas and feel even more comfortable with the setup. A lot of it was done with what was available to save money but we all know how that generally ends up in the long run!
Old Nov 25, 2010 | 09:20 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Chevysurfer, the gremlins I was having had absolutely nothing to do with my setup. One was due to the alternator pigtail not making sufficient contact with the alternator connector and causing intermittent voltage readings. If there is one thing I learned, check and re-check EVERYTHING!!!
Old Nov 26, 2010 | 03:12 AM
Car: 91 CAMARO RS
Engine: 305 TBI
Well thats good to know that it didnt have to do with your setup. It looks like you have done extra to insure everything works properly. You have a real nice ride, I use to live up in Louisville, I have seen alot of nice rides and camaros up there locally. My dad owns a body shop in Hillview off of bluelick rd. Its rite there at the border of Jefferson county and Bullit county. Ill be up there soon I hope to see some nice rides like yours.(Well after the nasty weather).
Old Nov 26, 2010 | 12:46 PM
DAVECS1's Avatar
Car: 91 GTA
Engine: 377ci
Chevysurfer, like I said in the beginning, I think your setup will suffice. If the car sees the road frequently, I would give everything a once over with each oil change. If it is a teack car, chances are your giving everything a visual before each trip to the track, so this should be fine also.
Welding wire is decent. I really like the braided stuff you have. Just need to watch fuel and oil contamination of the insulation. The conductor is great. Just thought I would throw some tips out there if you end up redoing anything, and I believe you under stood that:-) It is nice to have a logical two way dialog on making these cars better. Sometimes that can be hard to do with a large audience with varied opinions. Looks like you have done some good work to your ride and to me that is always respected.
Old Nov 27, 2010 | 11:19 AM
oguin_studking's Avatar
Car: 1990 Firebird Formula
Engine: 358
Transmission: 700-r4
Hey since you had to redo the wiring on the starter...I cannot figure out the correct wiring on it...i had to redo all of my wiring bc i went to carb. Just wondering if you could tell me what goes where on the starter? preciate it!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
64goatman
Sep 9, 2015 01:09 PM
Formula_88AE
Sep 3, 2015 01:47 PM
andy74
Sep 3, 2015 08:41 AM
