CS 130 Alternator Wiring Resistance?
Hey guys, I put a 350 in my jeep Tj and I'm working on wiring the alternator. i had a TPi setup so the alternator I got was a 3 wire alt Auto zone Part# 1367-6-11. I found a plug (has four prongs with 3 wires. I'm trying to figure out how to wire it. I know the red wire goes to the batt term. then to the battery. And the other wire is for volt meter. But the last wire is suppose to have a resistance in it. So i put a 1watt 100 ohm 5% resistor in the line and ran it to the start/run wires. Not working. Any ideas?
Car: camaro iroc-z
Engine: 355 L98 Corvette engine
Axle/Gears: 3.27 9 bolt borg warner
Re: CS 130 Alternator Wiring Resistance?
i got the same problem here.
i wil try a 270 Ohm 1 watt resistor for the inline or a 4 watt bulb.
do you have fix your problem now??
dennis
dennis
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
470 ohm resistor or 194 light bulb... That's the way the system was designed.
Car: camaro iroc-z
470 Ohm okey but howmuch Watt???
i got here also a 500 Ohm 2 watt can i use it?
Car: camaro iroc-z
and what do you mean with a 194 light bulb ??
howmuch watt?? 12v .. watt ???
thanks again dennis
thanks again dennis
194 is a type of bulb, think turn signals
Go to radioshack and get a pack 470ohm resistors. I use 1/2 watt resistors, PN 271-1115
Either use a resistor or install a light bulb
Car: camaro iroc-z
do you now how much resistance the light bulb hase
i was try to check the resistance on the light bulb but that is no 470 Ohm
it was a 194 light bulb
Engine: 2.7L V6
Axle/Gears: 4.41
You can't check the resistance on an unlit light bulb. The bulb's resistance goes up exponentially (in other words, a LOT) when lit because the heat generated by the filament increases its own resistance.
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Hot Topic
A 194 bulb is approximately 52Ω when hot.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog lights on in good weather beware. Low performance driver ahead.
How bout those nitwits too scared to drive without headlights in the daytime,
and the nitwits that need headlights for a little rain
Happy Racing!
If People Drove Any Slower They’d Be Going BackwardsWhen you see fog lights on in good weather beware. Low performance driver ahead.
eightsixseven
Dec 16, 2024 01:50 PM
Dialed_In
Aug 20, 2015 01:45 PM
db057
Aug 11, 2015 10:11 PM
