pulled neg cable and shut off wtf?
Old Oct 9, 2009 | 02:10 PM
tgill's Avatar
hey been searchin wires and **** all week but anyway i used my truck batt to start car cause its dead then went to switch cables so it would charge batt but pulled neg cable and it just shut down do u no what that means i no if it was positve that means altinator is shot can u help
Old Oct 9, 2009 | 05:53 PM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
Re: pulled neg cable and shut off wtf?
Same for the negative, the car doesnt' have any power to run the coil computer or any electronics. Alternator is bad.
Old Oct 9, 2009 | 06:44 PM
pbfreak9999's Avatar
Car: 91 camaro z28
Engine: 355
Axle/Gears: stock
bad altenator
Old Oct 9, 2009 | 06:53 PM
bitchin_buick's Avatar
Car: 91' bird(WS6>>305TBI), 82'Regal
Before you buy a new Alt. I'm sure you can have it tested at any autozone/murray's >>> I myself would do that and recheck your ground (clean & sanded to clean metal).... Good luck!
Old Oct 10, 2009 | 06:49 AM
resinlake's Avatar
Car: 2011 6.2 Silverado, 88/85 camaro
tgill, something as to check.. Take a wire brush or sand paper (220 grit?) and be careful and clean off the posts on your battery, the ends of the cables, and anywhere you see corrosion. Made a world of difference for me Worth a try before dropping some cash for a battery or alternator any day.
Old Oct 10, 2009 | 07:42 AM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Could be your voltage regular.. Don't drop the money on the alt. before you get that checked..
Old Oct 11, 2009 | 02:42 PM
tgill's Avatar
ok how do u check a voltage regulater and where is it and what is it i heard of it but is there a way i can check my wires that go to and from alt
Old Oct 12, 2009 | 05:51 PM
Pocket's Avatar
Car: 91 Trans Am
Its inside the ALT...
Get the ALT test and check all of your engine/chassis grounds. A broken ground to one of those would mean the batt cable is the only ground left and removing either off the batt opens the circuit killing the engine
Old Oct 14, 2009 | 04:21 PM
tgill's Avatar
thanks guys had it checked it is good so i started searching down wires again and none of them lead back to batt so apparently the previous owner thought the batt recharged it self but thanks for all your help
chazman
Aug 28, 2018 03:25 PM
86IROC112
Aug 31, 2015 07:00 AM
wayshegoes
Aug 17, 2015 12:00 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
