Fuel tank unit??? carbed engine
Old Nov 27, 2009 | 12:57 AM
Tightenloop's Avatar
Car: Camaro LT
Transmission: 700r-4
Hi,
Somebody have any ideas what "fuel tank unit" stands for on '87 Camaro LT with originally carbed LG4 engine and mechanical fuel pump.
I have switched to holley TBI, inline fuel pump and MegasquirtII ecu. Have maked up custom wiring. and now want to remove all unneeded wires.
Old Nov 27, 2009 | 10:55 AM
Pocket's Avatar
Car: 91 Trans Am
Re: Fuel tank unit??? carbed engine
In-tank fuel pump
Read this before you get too deep
https://www.thirdgen.org/forums/ltx-...p-3rd-gen.html
Old Nov 27, 2009 | 11:54 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Tank U
Fuel Tank Unit can refer to the fuel gage sender or other device in the tank. It helps to know the context of the discussion.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog lights on in good weather beware. Low performance driver ahead.
How bout those nervous nellies too scared to drive without headlights on in the daytime or if there is a little rain!
Old Nov 27, 2009 | 11:56 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Exactly, the '87 LG4 comes with a little helper in-tank electric. It won't put out much pressure as it was designed to assist the mechanical pump and prevent vapor lock. You'll probably be fine keeping it operational (I'd recommend it). If you disconnect it though, it will become a restriction if left in place.
Old Nov 27, 2009 | 08:33 PM
Pocket's Avatar
Car: 91 Trans Am
The "unit" is the direct output of the FP relay. Its safe to assume it is indeed an electric pump
Old Nov 28, 2009 | 01:00 AM
Car: Camaro LT
thanks everybody for help.
Now I understand why my high pressure fuel pump make a little more noise as i expected.
Old Nov 28, 2009 | 09:02 AM
naf's Avatar
naf
Don't neglect to include alternate controls for the existing in-tank pump. It is controlled by the existing ECM harness as the wiring diagram shows.
Old Nov 29, 2009 | 02:30 AM
Car: Camaro LT
Everything is fine, already connected it to high pressure fuel pump. Now Megasquirt2 ecu takes control over both.
mustangman65_79
Apr 14, 2017 05:37 PM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
AkDrifted
Aug 17, 2015 07:45 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
