86 Iroc Headlights flashing
Old Jan 7, 2010 | 08:39 PM
dfuller4's Avatar
Anyone have an idea as to why the headlights on our car decided to start flashing when on. It just started the past day or two we turn them on after a few minutes they begin to flash. Any help is appreciated right now its tough to drive at night
Old Jan 7, 2010 | 08:43 PM
Drew's Avatar
Re: 86 Iroc Headlights flashing
My best guess is the circuit breaker in your headlight switch is bad... It's overheating opening the circuit killing the lights, then closing, rinse and repeat.
Old Jan 7, 2010 | 08:51 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Or you have a short somewhere. Are all the lights on and normal brightness when they are on?
Old Jan 7, 2010 | 11:39 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
It's got the 2010 bug man. It's alive lol. It's alive lol. Nah bro, I got no clue. Does the Camaro have a car alarm that your not aware of.
Old Jan 7, 2010 | 11:40 PM
dfuller4's Avatar
Thanks for the reply's we appreciate the help
Did a little checking the past few hrs. for wire shorting to ground did not find anything apparent and we have not blown a fuse
Was not aware headlight switch had breaker will ck that out
THANKS
Old Jan 7, 2010 | 11:42 PM
DAREDEVIL 1's Avatar
Car: CAMARO,GMC SUBURBAN DUALLY,RACEBOA
Engine: 305 TBI( soon 383),350Vortec
Transmission: 700 turbo
I know what it is .......ITS ACOP CAR !!!!!! LOL
Sorry , could not resist.LOL
Hope u find the problem !!!!!!
Old Jan 7, 2010 | 11:45 PM
dfuller4's Avatar
That's the best
I better ask my Nephew who's a cop what he did
Old Jan 8, 2010 | 12:09 AM
Stephen's Avatar
Car: 87 GTA
Maybe my headlights off my old 92 RS ended up on your car! When I was a Volunteer Firefighter, I had Wig Wags on my headlights, like I do on my GTAs turn signals!
My Wig Wag lights
But seriously.....Do they flash together? My guess might be an old car alarm that was not fully uninstalled.
Old Jan 8, 2010 | 12:17 AM
shelby7099's Avatar
Car: 1984 Camaro Z28
Engine: 350ci
Axle/Gears: 3.31 non posi = no traction
Has anyone hacked into the headlight wiring??
Old Jan 8, 2010 | 12:34 AM
midnightfirews6's Avatar
Car: 1984 Trans Am WS6
Engine: LG4
Axle/Gears: 3.23 LSD
Sounds like a headlight switch since you said it doesn't happen immediately.
Old Jan 8, 2010 | 12:23 PM
dfuller4's Avatar
Thanks for the help To answer a few questions..
Lights are bright when on and never dim when flashing
They do flash together
We have had the car for awhile wiring harness has no evidence of someone messing with it. Still wrapped in factory plastic wrap
Will try and do more testing tonight
Old Jan 8, 2010 | 06:01 PM
My Wig Wag lights
Hey, Thats what I asked. Just kidding. Thats what I thought too, but then the headlights would start flashing the moment he turns the key, not to mention that even if there was a car alarm still installed, the starter kill mechanism in the alarms module would prevent the starter from engaging due to the alarms relay grounding out.
Old Jan 8, 2010 | 06:03 PM
Does it flash in perfect sequence or rythem? Or is it a flash that varies in speed (flashes).
Old Jan 8, 2010 | 06:42 PM
Stephen's Avatar
Car: 87 GTA
Not necessarily.
If it is faulty, it could be a problem with an alarm that is intermittent. Only the headlight portion of an alarm could still be functioning, not the starter interrupt portion. Or not even part of the alarm to begin with.
Old Jan 8, 2010 | 06:52 PM
dfuller4's Avatar
No alarm ever installed we know original owner
Lights seem flash to a pattern
Old Jan 8, 2010 | 07:10 PM
Flashes all the time as in while vehicle is in motion, when you hit a bump? Try this, turn the key to on position but do not turn on car. Then turn on lights and see if they begin to flash. The point is you want to see if it occurs while car is on, or while car is off. Also try it with the ignitoin off and just turn on headlights. Also, does your Camaro have fog lights? If so, then your relay is probably going bad that goes to the fog lights. On my 86 IROC, I can have the low beams on with fog lights, but once I switch to high beams, the fog lights go out because of the relay. Food for thought.
Old Jan 8, 2010 | 07:19 PM
dfuller4's Avatar
Thanks again for replys, car is on way home wife had it. It will does it while driving or sitting with car on. I have not tried other scenarios but will when it is here it has fog lights they work off another independent switch Thanks again
Old Jan 8, 2010 | 07:20 PM
Stephen's Avatar
Car: 87 GTA
.....On my 86 IROC, I can have the low beams on with fog lights, but once I switch to high beams, the fog lights go out because of the relay. Food for thought.
That is the way the factory did them, so that is perfectly normal. Also VERY easy to bypass!
Old Jan 8, 2010 | 07:42 PM
dfuller4's Avatar
OK she got home two cars pulled over due to lights flashing (might leave it)
They do it with engine off key on, key off or running. It actually looks like it Morse code
where they are on flash pause flash 4 times the on 2-3 sec. flash 5-6 times the on did not sit there long enough to look for a repeatable pattern.
Old Jan 8, 2010 | 07:47 PM
Stephen's Avatar
Car: 87 GTA
If it is a consistent pattern that repeats, over & over....
That DEFINITELY sounds like an emergency headlight flash pattern, commonly used in police, fire or ambulance vehicles. Mine were Wig Wags (alternating) but before that, they were tied together & could have easily flashed together.
Drew's Avatar
I'll say it again since it's been 24 hours... The circuit breaker in your headlight switch is probably failing.
From the service manual.
Circuit Operation
Voltage is applied to the Light Switch at all times. The Light Switch includes a self resetting circuit breaker. The circuit breaker opens when the Headlight circuit draws too much current. When the circuit breaker opens, it interrupts the current flow. With no current flow, the circuit breaker cools off and resets automatically. When the Light Switch is in HEAD, the Dimmer Switch directs voltage to either the Lo Beams or the Hi Beams. The Hi Beam Indicator also receives voltage along with the Hi Beams.
You can test it without replacing the switch. You've got a red wire and a yellow wire into the switch. The red wire goes directly to 12v constant. The yellow wire goes out to the hi beam/low beam switch and on to the headlights. Turn on the headlights at the switch. When the headlights start flashing, connect a test light between the red wire and a ground, does the test light flash or stay lit solid? If it stays lit full time, then the problem is in the switch, or further down the circuit. Do the same test but between ground and the yellow wire, does it flash or stay solid? If it flashes, replace the switch.
Old Jan 8, 2010 | 08:05 PM
dfuller4's Avatar
Drew Thanks
Will try it in tomorrow, I REALLY appreciate all the advise and help from all.
Old Jan 8, 2010 | 09:39 PM
How do you bypass? I know wherer the relay is at, but what should I pull and strip and solder together?
Old Jan 8, 2010 | 09:42 PM
Hi Drew, my name is Andrew (86Chevy IROC-Z). Good source. Straight from the manual. Nice.
Old Jan 8, 2010 | 09:53 PM
Stephen's Avatar
Car: 87 GTA
Not sure where the Camaro relay is but.....
http://www.austinthirdgen.org/index.php?pid=17
Old Jan 8, 2010 | 11:04 PM
Stephen, YOU ARE THE MAN, MAN.. Thanks bro. Im going to do that 1st thing in the morning. Peace.
Derick15
Sep 17, 2016 05:28 PM
DiabolicalRS
Aug 26, 2015 07:35 AM
soarestransam
Aug 24, 2015 08:15 AM
Fronzizzle
Aug 17, 2015 02:52 PM
mustangman65_79
Aug 11, 2015 03:17 PM
