wierd headlights..
Old Apr 11, 2010 | 09:23 PM
overboost07's Avatar
Car: 1988 pontiac trans am gta
Engine: 305 tpi
Axle/Gears: factory
wierd headlights..
ok so i just put a new fog light switch in my car and the headlights have been acting funky, when i flip them on sometimes they wont go up... theyll turn on and point at the ground but not go up. pretty sure its not a loose wire because i was just out there with them turned on but they were down and all the sudden they come up. i tried several times and they worked fine, just sometimes they dont wanna work unless you leave them on for a few minutes, then all the sudden theyll pop up. i put my other foglight switch back in to make sure with no change. nothing else has changed with the car. i dont know what it could be
Old Apr 12, 2010 | 07:11 AM
Engine: 305 tpi
Axle/Gears: factory
Re: wierd headlights..
ttt
Old Apr 12, 2010 | 07:57 AM
The_rabbit1's Avatar
Car: '87 Iroc
Engine: 350 .060 over
Axle/Gears: 3.70 9bolt
Motor controller sounds like.
Old Apr 12, 2010 | 07:59 AM
Engine: 305 tpi
Axle/Gears: factory
where in the world is that?
Old Apr 12, 2010 | 09:00 AM
Stephen's Avatar
Car: 87 GTA
On the firewall. As your facing the car...Right of the engine, left of the brake booster.
http://www.top-downsolutions.com/pro...roducts_id=138
Old Apr 12, 2010 | 09:06 AM
Engine: 305 tpi
Axle/Gears: factory
that says for 90-02 mine is a 88 could their be something else causing it?
Old Apr 12, 2010 | 09:18 AM
Stephen's Avatar
Car: 87 GTA
I wasn't trying to say that you need to buy that one from him, but they all look the same, so it gives you a good idea of what to look for.
I'll go look at my 87 one, but IIRC, mine looks exactly like that one. I know mine is about 4" square with 2 plugs in it, just like in his pic.
Old Apr 12, 2010 | 10:19 AM
Engine: 305 tpi
Axle/Gears: factory
any way i can check to see if its bad? is there a way to fix it or just replace?
Old Apr 12, 2010 | 10:47 AM
Stephen's Avatar
Car: 87 GTA
When my headlights won't pop up (hasn't happened in over a year now) a light tap on the control box makes them com up.
I either look for a speed bump to run over (typical 2mph, nothing major), road seam, or just standard vibrations from driving. If I turn them on & they don't come up, I just keep driving until they do, or if it really does start to get too dark, I pull over, pop the hood, & tap the box with my hand.
Here's mine off a 89 GTA (on my 87 GTA).
I'd ask TSD about his headlight controllers & the 90. It looks just like my 87 & 89 controllers. As to my knowledge, only the 82-84 (85?) ones were different, because they were 2 individual ones, mounted up by the headlights themselves.
Old Apr 13, 2010 | 10:13 AM
Engine: 305 tpi
Axle/Gears: factory
thanks stephen!!
mud runner
Nov 2, 2015 07:30 PM
lanceflame44
Sep 25, 2015 12:28 PM
andy74
Sep 3, 2015 08:41 AM
Apeiron
Carburetors
Oct 18, 2001 04:54 AM
gruveb
Sep 29, 2001 03:06 PM
