Need 82 firebird cluster connector pinout
Old Jun 13, 2010 | 11:32 AM
Jupiter's Avatar
Car: 82 Trans Am
Engine: 383
Axle/Gears: Built 4th gen 3.42 posi/disc
Guys i am trying to install an 89 GTA electric speedo cluster in my 82 T/A.
I have the 89 cluster connectors pinout and i now need the 82 cluster pin out in order to complete my conversion.
Old Jun 20, 2010 | 07:58 AM
Jupiter's Avatar
Car: 82 Trans Am
Engine: 383
Re: Need 82 firebird cluster connector pinout
bump
Old Jun 24, 2010 | 07:48 PM
Jupiter's Avatar
Car: 82 Trans Am
Engine: 383
BUMP
Somebody somewhere must have done this conversion sometime!
Old Jun 24, 2010 | 08:08 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
try here
http://www.austinthirdgen.org/mkport...ntents/images/
Old Jun 24, 2010 | 08:44 PM
Jupiter's Avatar
Car: 82 Trans Am
Engine: 383
Originally Posted by vetteoz
Thanks but i already looked there and though there are many good diagrams
there, the one i need is not.
This is what i have and need the same for 82 firebird
Old Jun 25, 2010 | 01:10 AM
82CrossFire Z28's Avatar
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
Here are the cluster diagrams for an 82 Camaro. I expect they would also apply to the 82 Firebirds. Sorry, it would take me a few days to figure out all the wire colors, but you should be able to get them from the connectors and the diagrams.
Note that the second cluster diagram, with all my notes on it is from an 82 Camaro Z28 with the CFI engine.
As you can see, several of the indicating lamps are not on the cluster itself, but below it. They will have separate wire harness connectors.
Dave
File Type: pdf
Old Jun 25, 2010 | 08:17 AM
Jupiter's Avatar
Car: 82 Trans Am
Engine: 383
Wish that was for an 82 carb'd firebird.
I have tried to use the 82 camaro information from
Unfortunately too many differences and it didn't work
Thanks though
Old Feb 12, 2011 | 10:20 PM
tango1112's Avatar
Car: 1982 Firebird
Engine: 355 CID
Did you ever find the pinouts for the 82 firebird?
Old Feb 16, 2011 | 09:13 PM
Jupiter's Avatar
Car: 82 Trans Am
Engine: 383
Look here
https://www.thirdgen.org/forums/inte...-w-manual.html
Jeremys87
Jul 14, 2022 09:08 PM
Dialed_In
Aug 20, 2015 01:45 PM
tnrednneck
Aug 13, 2015 08:57 AM
ChevyZ71
Aug 13, 2015 07:30 AM
