Any Ideas on getting headlights up??
Old Jun 18, 2010 | 07:27 AM
GTA1987GTA1988's Avatar
Car: 1987 GTA
Engine: 5.7
Axle/Gears: 3.27 posi
I have looked through the forum and I haven't found any good explanation on how to get the headlights into the up position when they are broken in the down position. I have a TDS rebuild kit and i didn't read any explanation on how to get the bucket up. I know this is a repeating problem that is asked of the board so please excuse another asking. I have an 1987 GTA if that is needed.
Old Jun 18, 2010 | 11:07 AM
Pocket's Avatar
Car: 91 Trans Am
Re: Any Ideas on getting headlights up??
On the top of the motors is a ****. Turn it to the right to raise, left to lower. You may have to help the light come up with your hand if the bushing are completely destroyed
Old Jun 18, 2010 | 05:37 PM
Car: 1987 GTA
Engine: 5.7
tried that it doesn't work.
Old Jun 18, 2010 | 06:11 PM
ternandes's Avatar
Car: 88 GTA
Transmission: WC T5
Axle/Gears: BW 9-bolt 3.27 posi
The gear ratio is very low, so you end up having to do many turns just for it to move a little bit.
Old Jun 18, 2010 | 06:36 PM
Drew's Avatar
If turning the **** doesn't raise/lower the lights, then the internal gears or clutches are shot and the motors need to be rebuilt.
Old Jun 18, 2010 | 07:38 PM
Car: 1987 GTA
Engine: 5.7
I just got the motors out and I found that they are shot and I have just rebuilt them but the bad thing is that the pivot on the passenger side is broken do you think j-b weld will hold that together?? The pivot was the main problem on that side the other side popped up with pressure and turning the ****. I just forgot the direction to turn thanks for posting that.
Old Jun 19, 2010 | 08:35 AM
Pocket's Avatar
Car: 91 Trans Am
No, source a replacement arm. They get quite a bit of force and any bond short of a weld will fail quickly
Old Jun 19, 2010 | 09:21 PM
Car: 1987 GTA
Engine: 5.7
It wasn't the arm it was the mount for the bucket. The pivot point that the light raises on not the lift arm. Will that still get a lot of stress or can it work with the j-b weld?
Old Jun 19, 2010 | 09:31 PM
gmonly's Avatar
Car: 88 chevy k1500 reguar cab, 8' box
Engine: super duty TBI 350
Transmission: 4L80
Axle/Gears: posi 3.73
that will still be a lot of force, the j b weld will not hold the pressure.
Old Jun 19, 2010 | 10:18 PM
Car: 1987 GTA
Engine: 5.7
OK well here is hoping that at Back to the Fifties Swap meet there will be some one with the Passenger side headlight bucket assembly for a Firebird.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Jetmeck
Sep 4, 2015 12:29 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
