Acc fuse location
Old Jul 13, 2010 | 04:44 PM
86maroresto's Avatar
Car: 86 iroc z28
Engine: 383 stroker, vortec heads
Axle/Gears: 3.73's
Acc fuse location
So my horn, dome light aren't working and i've read that it could be from a blown acc fuse. Now i can't find which one that is. I can't find a fuse diagram anywhere for an 86. Can somebody please give me the location on the panel!
Old Jul 13, 2010 | 09:12 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Acc fuse location
I can tell you it's a 15 amp, so that will narrow the search. If you can't find it, pull them all one at a time and check.
Old Jul 13, 2010 | 09:15 PM
Car: 1992 RS
Engine: Carbed 350
This is a 1985 - should be basically same:
https://www.thirdgen.org/forums/elec...use-block.html
is your friend!
Old Jul 13, 2010 | 09:31 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
just look at the fuse panel. or use your owners manual
Old Jul 13, 2010 | 11:07 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Same fuse works radio, lighter, power mirrors and locks, third brake lights, front side marker lights as well? Is all this stuff out? I've had a similar problem. Let me know if replacing the fuse results in it rapidly popping again. If replacing the fuse works well, great!
Old Jul 15, 2010 | 11:50 PM
Car: 86 iroc z28
Axle/Gears: 3.73's
found the location and its not blown. The car doesnt have a radio and the doors are off so i can't check the mirrors or locks. The hatch is off too. (repainting everything/body work) So no 3rd brake light. All i know is that the horn did work prior to the trans swap and now doesn't. Maybe the wires off the starter? I read that somewhere, just dont know which to check or what to look for. Thanks for the help.
Old Jul 16, 2010 | 10:51 AM
Car: 1992 RS
Engine: Carbed 350
did work prior to the trans swap and now doesn't. .
Tranny swap huh? Did you get the ground straps reconnected properly? There is a ground strap that comes off the top pass side engine-to-tranny bolt. There's also a ground strap from rear pass head to body - maybe you missed one of those or maybe they need a bit of sanding where they connect to get a good connection.
Old Jul 17, 2010 | 09:31 PM
Car: 86 iroc z28
Axle/Gears: 3.73's
Not sure if it makes a difference but i have a 350 truck engine in the car and honestly I dont remember taking and ground wires off when i removed and installed the trans. But anyway I put the doors and hatch back on and no power locks/mirrors. Dont have a 3rd brake anymore so that doesnt matter. But the cig lighter is working and so is hatch release and like i said no blown fuse. Is there something i'm missing here?
Old Jul 17, 2010 | 09:33 PM
Car: 86 iroc z28
Axle/Gears: 3.73's
No fuse blown. Got any other ideas since you've had this happen?
Apprecite any info!
Johnoooooo
Sep 22, 2015 08:55 AM
gta892000
Sep 16, 2015 12:37 AM
timonator
Sep 10, 2015 07:55 PM
64goatman
Sep 9, 2015 01:09 PM
tonys91rs
Sep 2, 2015 07:07 PM
