Fully Mech/Vaccum Dist and Knock Sensor?
Car: 88 Camaro
Engine: 305 TBI
With a hei dist (non computer controlled) the knock sensor and est become useless, because if they sense knock and tell the computer to pull timing it wont happen since the dist is no longer computer controlled. Am I right?
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Fully Mech/Vaccum Dist and Knock Sensor?
Yes but if you had a non computer controlled ( carb ) engine setup you would probably remove the computer anyway
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You're right unless it's using a 5 pin module.
Engine: 383 Carb
Transmission: 4L60
This isn't with the stock distributor, is it?
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Your going to have a problem if your trying to run a TBI unit with a vacuum advanced dist - the computer takes the info it gets from the sensors and adjusts fuel to the injectors. If running fuel injection you HAVE to have a computer controlled dist.
Car: 88 Camaro
Engine: 305 TBI
well sh*t..i thought those msd streetfire distributors were made for these cars..everybody on here talks about it and it was on summit under 91/pontiac/firebird/305...i already cut the wires for it and everything..
Engine: 383 Carb
Transmission: 4L60
The 8366 is for computer-controlled setups, the 8362 Street-fire is for non-computer control.
FormulasOnly
Sep 10, 2015 09:07 PM
