Lights behind speedo wont work.
Old 10-20-2010, 11:38 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
I have an 85 Z28 and the lights behind speedo won't work. Also one have of Heater controls won't light up. Any ideas or suggestions would be greatly apreciated
Old 10-21-2010, 12:34 AM
mdihotmale's Avatar
Car: 1989 irocz,87irocz,05 tacoma trd
Engine: 5.7's,5.0.4.0
Transmission: a4, an sixspeed
Re: Lights behind speedo wont work.
take out the gauge cluster ,remove front face peice,then take out the little bolts i think 6mm , then the two 10mm in the check engine spots, one on each side ,an there are like 10 little light bulbs, replace them all while your in there, also for your heater unscrew an remove an little light plugs in the back of it, or remove radio an reach up an twist an pull light out an replace bulb, before you buy bunch new lights swap some from behind your tach an make sure this is the problem
Old 10-21-2010, 07:30 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Info and pics below:
https://www.thirdgen.org/forums/faq-...-fix-pics.html
JamesC
Old 10-21-2010, 08:08 AM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Here is the thing. I have taken it all out. Everything else on cluster lights up. I do have to wiggle the light switch some times, but they light up.
Old 10-21-2010, 09:30 AM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
I read entire thread. Did Not see anything about lights
Old 10-21-2010, 09:38 AM
JamesC's Avatar
More about cluster/light removal. In your initial post you didn't mention that you'd already removed the cluster. Guessing, it sounds to me as if you have burned out bulbs as well as a switch issue.
JamesC
Old 10-21-2010, 09:44 AM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
I looked at all bulbs. Looked good. The lights behond all other gauges work. Just not speedo. Could harness on that side have something to do with it?
Old 10-21-2010, 10:01 AM
JamesC's Avatar
An easy check, as mdi suggests, is to swap in a bulb that you know works, then I'd clean the contacts on the driver's side, reinstall and see what happens. Make sure the cluster is well seated.
JamesC
Wade787b
09-29-2015 01:15 PM
IROCZDAVE (88-L98)
08-24-2015 06:54 AM
Omega
08-10-2015 12:46 PM
beachrodder
08-07-2015 04:27 PM
Quick Reply: Lights behind speedo wont work.
