Connector in console?
Old Dec 15, 2010 | 08:47 PM
chevydrvr's Avatar
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
I need to wire my reverse light switch on my B&M shifter and I need to connect to the green and blue wires on the connector that is in the center console. How do I do that? Before when I was testing whether or not it worked before I out it all together, I would just put the wire into the holes in the connector. What is the right way to do it?
Another question. What is this connector for anyway? Was it connected to the stock shifter? I want to put the stock shifter back in someday after I get the camaro on the road for a while.
Thanks for the help guys.
Old Dec 16, 2010 | 01:45 AM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Re: Connector in console?
Any pictures? The only wires that I know are the shifter selector light, nuetral safety switch, and the glove box light. There may be more but I'm really not too familiar with that particular area. Ive only gotten that area once when I changed my shifter cable.
Old Dec 16, 2010 | 05:38 AM
chevydrvr's Avatar
Well in my camaro there is a black connector with maybe 10 wires connected to it. It looks like another connector should connect into that one. Sorry, I don't have any pics. I won't be able to work on the car until sunday, if at all! Hate this New England weather.
Old Dec 16, 2010 | 09:08 AM
Brads RS's Avatar
B&m should have the directions to wire the switch correctly. Its deals mostly with the park neutral switch and the back up lights. You will need the park/neutral switch to work correctly if you want your emissions systems to work. I will see if i can find a link for you.
Old Dec 16, 2010 | 09:11 AM
Brads RS's Avatar
http://www.bmracing.com/bmracing/ins...truction/8.pdf
On page 4 of instructions. Gives call out of wires and how to wire it correctly
Old Dec 16, 2010 | 12:16 PM
chevydrvr's Avatar
I know how to wire it, I just want to know the proper way to connect it to the black connector in the console. I feel like it isn't right to just push the wires into the connector slots and leave it that way. Are there crimp on connectors for this?
Old Dec 16, 2010 | 12:41 PM
Call b&m. I'm sure they have or can direct you to the place to make the application like how its suposed to be. After all, they do make a shifter specifically for our third gens.
Old Dec 16, 2010 | 02:29 PM
chevydrvr's Avatar
Can anybody who has installed this shifter post pics as to what they did?
Old Dec 16, 2010 | 04:08 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Why not just use these:
http://www.wiringproducts.com/contents/en-us/d265.html
They are available at any local autoparts store - they crimp on the wire, then you use a crimp-on male spade connector - that way you can leave your OEM connector in tact and just 'tap' in on thw wires you need.
Old Dec 16, 2010 | 04:16 PM
chevydrvr's Avatar
Thanks, Ill see if I can find some of those.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
Veaceonee
Sep 29, 2016 08:15 PM
ndndndnd
Sep 28, 2015 08:00 AM
chuck13
Interior Parts Wanted
Sep 22, 2015 11:19 AM
88HARDTOPIROCZ
Sep 18, 2015 10:30 PM
