Any ideas what this connection is?
Old Dec 16, 2010 | 01:18 AM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
I found out that I was missing a junction for all my power leads and henryd3 helped me out. Now I got another question. What exactly is this that I put inside of a multi colored box? I can see that they are connections but for what? Thanks in advance guys.
Old Dec 16, 2010 | 11:23 AM
Pocket's Avatar
Car: 91 Trans Am
Re: Any ideas what this connection is?
Fuel pump/ECM batt 12v fuse
Black thing bolted to the frame rail is just a cap. Inside is a fan connector with a 20A blade fuse
Old Dec 16, 2010 | 10:04 PM
So then on that fender area, there is 2 enclosed fuses and one cluster of grounding points right? On my 86, there is only one enclosed fuse mounted in that area.
Old Dec 17, 2010 | 11:02 AM
Pocket's Avatar
Car: 91 Trans Am
Its one fuse that protects both circuits
Thats not a ground block, its a power block. The wires should be red and connected to the battery. Touching any of them to ground should make quite a spark show and pop loads of fuses/links
Old Dec 17, 2010 | 07:36 PM
Well according to the legend or key on the lower right, the #3 is negative which does show that it is bolted to the frame with 2 ground wires while #2 has the red wires that are positive. My IROC only has one fuse box (not 2 like how it is displayed in the picture) and 1 ground wire. Makes me wonder far the PO went to solve the issue that he may of had in the area.
camaro11j
Sep 19, 2018 08:49 AM
fbirdroller
Sep 2, 2015 10:27 PM
Justin69
Aug 31, 2015 11:31 AM
Bull86
Aug 10, 2015 05:43 PM
