Push to start
Old Feb 25, 2011 | 08:02 PM
IROCZdude's Avatar
Car: 88' Z
Engine: 350 .60 over
Transmission: W/C T5
Push to start
What do you guys think?
Old Feb 25, 2011 | 08:38 PM
1986350's Avatar
Car: 1985 Pontiac trans am
Engine: 350 4bbl
Transmission: 5-Speed
Axle/Gears: limited slip
Re: Push to start
i love the idea lets some more followers!!!!!!
Old Feb 25, 2011 | 08:46 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: Push to start
You're talking about a pushbutton starter?? Its been done by a few, myself included. You just need the pushbutton, a relay, and some wiring. If you want I can post up the wiring diagram I made for mine tomorrow.
Old Feb 25, 2011 | 08:56 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Push to start
I built a system years back for an old V6. The novelty wears off quickly
If you use on,e Id highly recommend using a relay instead of pumping power through your push button switch
Old Feb 25, 2011 | 09:19 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Push to start
Originally Posted by IROCZdude
Push to start
Hard part is jumping in the car and getting your foot on the clutch and into gear before car slows down too much
Old Feb 25, 2011 | 09:20 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Push to start
The old fashion trick way was a button under the gas pedal, with the safety removed for the gear selection, you jump in your car and at the same time put it in gear and stomp the gas and speed away from the crime scene. [The ign lock cylinder would also turn without a key.]
Old Feb 26, 2011 | 11:12 PM
IROCZdude's Avatar
Car: 88' Z
Re: Push to start
a wiring diagram would be nice
Old Feb 26, 2011 | 11:36 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Push to start
Lots of ways to do it, if you are gonna have a 3rd gen for more then a week, spen $20 on the service book. wiring in the back.
the most simple way is just run a 12v wire right to the starter solinode.
long as the key is on, it will start, no need to change anything as is stock.
run a wire from fuse box to button, from button to starter n your done.
Old Feb 27, 2011 | 12:05 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: Push to start
Originally Posted by Gumby
run a wire from fuse box to button, from button to starter .
But like Pocket said above;
you don't want to running solenoid voltage through the push button.
Better to us the button to operate the relay ( could rework existing starter enable relay from VATS system)
Old Feb 27, 2011 | 12:08 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: Push to start
http://www.austinthirdgen.org/mkport..._continued.gif
Old Feb 27, 2011 | 12:13 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Push to start
Someone must not know how they work, the activation side of of it, is a low power small wire, not allot of juice at all. A speaker wire could carry more then enough juice. It is a relay, low amps comes in and activates the high amp side.
Old Feb 27, 2011 | 01:03 AM
92z28camarokid's Avatar
Car: 97 Cummins 92 CamaroZ28, 94 GSXR750
Engine: Modded 5.9 , carbed sbc358, modded
Transmission: Nv4500, 700R4 (for now)
Axle/Gears: stock
Re: Push to start
I've got a push button start in my car too, still need the key to turn on the fuel pump though
Old Feb 27, 2011 | 02:21 AM
88gunmetalgta's Avatar
Re: Push to start
I'm with ya there. Plus for a person my size it takes way too much effort to make too many 5 minute stops, unless they're all on top of a hill.
The only way I'd install a push button starter is if I could push it once, and it would crank til it starts, (or 5 sec if it doesn't catch). But that would take circuitry beyond my current skillset.
Old Feb 27, 2011 | 07:42 AM
Pocket's Avatar
Car: 91 Trans Am
Re: Push to start
There is a reason your solenoid wire is 10-12ga. Try using 20ga and see what happens
Old Feb 27, 2011 | 07:20 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Re: Push to start
A push button starter just takes the place of the "crank" position of the ignition key. I don't have the diagram on my home computer(its on my work pc). I'll post it up when I get to work tomorrow.
The way I did it, you can hide the button and it makes a nice little anti-theft measure as it completely disables the start function of the key. Even if the thief rips the ignition cylinder out it will not start.
Old Feb 27, 2011 | 08:30 PM
Re: Push to start
I know how to run them that way, so you have to hold down the button til it starts, what I'd like to see is push the button once and the car starts up.
Whats better is a hidden fuel pump switch. Then just leave your keys in the car, and if someone tries to steal it, they only get as far as the fuel in the float bowl will let them!
Old Feb 28, 2011 | 08:09 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Re: Push to start
Here is the diagram I made up when I installed the push-button start. I basically just disconnected the yellow wire that goes to the start enable relay at the base of the steering column and connected it to a relay activated by my button. I probably could have run it straight through the button since its rated at 30 amps, but I figured the relay was a safer way to do it. And I have a whole bunch of them laying around.
88gunmetalgta - I thought about doing that with mine. It wouldn't be much more difficult than what I did, but with having a manual choke on my carb it doesn't like to start some times. I also had some fueling issues on startup when I did this and it would start and run till the fuel bowl emptied, then I'd have to restart it.
The other problem with letting them get as far as the fuel in the bowls is what happens when they run out. If you live on a hill like I do then they end up ramming the car into something to get it to stop rolling down the hill.
I also can't leave my keys in my Camaro because I shaved the door handles and the remote for the popper is on my keyring.
Old Feb 28, 2011 | 07:53 PM
IROCZdude's Avatar
Car: 88' Z
Re: Push to start
thanks everyone!
Old Apr 6, 2011 | 09:17 PM
Mud's Avatar
Mud
Re: Push to start
Here is a nice kit by StarDrive. It uses rfid. Of course you will need to bypass the vats and steering wheel lockout.
http://www.auto-hub.com/stardrive_pu..._ignition.html
Old Apr 6, 2011 | 11:03 PM
Highwind's Avatar
Car: 1988 Firebird
Engine: 305 TBI
Re: Push to start
Here's another vendor I saw on another forum just today that has a product with similar features and the fob is flat enough to fit in your wallet! I break/crack credit cards in my wallet often so not sure that's a good idea though .
http://www.auto-innovatio.com/magent...ech-st800.html
Old Apr 7, 2011 | 09:18 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Push to start
put your wallet in your front pocket, safer in every way.
Old Apr 7, 2011 | 12:18 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Push to start
Here's something to consider if using a relay and you have a hatch release button ...
The hatch release button gets it's ground for the hatch release relay from the purple starter wire. The purple starter wire is grounded by the starter until the key is tuerned, when it gets 12v+ from the green wire in the NSS.
Now - if you incorporate a relay into a push button start scenerio, and you have a hatch release button, as mentioned it takes very very little (as low as 200 milliamps) to activate a relay. That hatch release button does not ever have enough current through it to activate the starter solenoid, BUT it can get plenty enough current to it to activate a relay.
Thus, you must be careful, or you'll end up with a situation where pushing the hatch release button will run the starter, regardless of the key in the ignition, whether the car is in park or drive, or anything else (since it takes so little current to activate the coil inside a standard SPDT auto relay).
Old Apr 7, 2011 | 12:22 PM
Car: 1992 RS
Engine: Carbed 350
Re: Push to start
Push button start is pretty easy in the later cars anyway - if you dig under the driver dash, you'll find a connector with the purple starter wire and the dark green wire together. Looks like maybe it was a connector for a remote start button for the service techs to use in the day. I think you can just wire into that with any standard push button starter switch.
Not sure the NSS has anything to do with this connector or not (in other words, car might start in gear using these wires at this connector), but key would still have to be in ignition and on (since the green wire doesn't get any power without the key).
Old Apr 8, 2011 | 12:00 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Re: Push to start
I've never had that problem in my Camaro, so I got curious. I checked the wiring diagrams I have, and it appears that it only grounds through that purple wire on F-bodies with an automatic transmission. Manual transmission F-bodies like my Camaro ground through the parking brake switch.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
86White_T/A305
Aug 17, 2015 12:16 AM
apie2546
Aug 10, 2015 05:43 PM
Sherpajames
Aug 7, 2015 06:56 PM
