Please help me identify these!!!!!
Old Jun 29, 2011 | 08:38 PM
jbmillenium's Avatar
Car: 91 ws6
Engine: tpi 350
there are several unplugged wires under my dash, im trying to find out what they are, one has a vacuum line on it and one under the steering wheel is simply cut, i think the cut one is for the air bag. please help im trying everything to get this car running and im sure all this stuff unplugged is not helping.
this is where the first pic wire comes from, behind the brake under the carpet.
this one is to the left of the brake pedal coming over the plastic
this is the bottom of the blue one in the first pic
Attached Thumbnails Please help me identify these!!!!!-photo-3-.jpg   Please help me identify these!!!!!-photo-8-.jpg   Please help me identify these!!!!!-photo-6-.jpg
Old Jun 29, 2011 | 09:18 PM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Re: Please help me identify these!!!!!
Yellow is airbag
Old Jun 29, 2011 | 10:21 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Fill us in on what type of car you're working on.
And dial up the resolution on your camera a few notches.
Old Jun 29, 2011 | 10:28 PM
Car: 91 ws6
Engine: tpi 350
its a 91 ws6, with a 350 tpi from an 89, ill post some more well lit pics, these were from my phone
Old Jun 29, 2011 | 10:44 PM
Car: 91 ws6
Engine: tpi 350
ok, here are some clearer pictures. i figured the yellow was airbag, that wont effect running will it? i doubt it.
here is blue wire with vacuum line
2 unplugged in this one, the one way in the back to.
diff angle
Old Jul 1, 2011 | 11:18 PM
Car: 91 ws6
Engine: tpi 350
no one? please i need help
Old Jul 2, 2011 | 11:48 AM
Pocket's Avatar
Car: 91 Trans Am
Yellow mean airbag. Connectors, tape, anything yellow, dont mess with. No, it wont prevent the car from running
The harness with the large vacuum hose is cruise. Look over the top of the column for the mate. Hose connects to the right side brake switch on the barb
Large square is a relay socket for some option you dont have. Theres on in the camaro RS in my garage too going nowhere
2 row connector bolted to the fuseblock is the ALDL. Hook your scan tool up to this or use a paperclip to ground out two pins to pull the trouble codes if the MIL comes on
2 pin Yel/PPl connector in the back is an inline connector for the clutch safety switch on manual cars. Yours is auto so dont worry about this one either
Old Jul 2, 2011 | 05:14 PM
Car: 91 ws6
Engine: tpi 350
thank you. ive been trying to figure this out for a week. thank you again
Linson
Sep 21, 2015 01:08 PM
abrilnelson89
Sep 17, 2015 10:41 AM
Tweeks25
Sep 17, 2015 08:04 AM
abrilnelson89
Sep 16, 2015 02:19 PM
angel2794
Sep 8, 2015 06:22 PM
