5.3 PINS
Old Aug 3, 2011 | 07:56 PM
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
5.3 PINS
ok, can someone please provide me with a correct pin up for a 5.3 that will basically plug and play in my car??? thanks!
Old Aug 4, 2011 | 09:30 AM
Pocket's Avatar
Car: 91 Trans Am
Re: 5.3 PINS
What are you expecting to see?
A 5.3 is a swap, so any wiring would have to be a graft of the 3rd gen wiring and the new EFI harness. Every car is different so this question cannot be answered with a simple "pin up"
Old Aug 4, 2011 | 09:49 AM
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
Re: 5.3 PINS
i just need to know which pins go where to make it standalone
Old Aug 4, 2011 | 10:52 AM
Pocket's Avatar
Car: 91 Trans Am
Re: 5.3 PINS
http://www.lt1swap.com/2000harness.htm
You dont need to turn it into standalone for a 90
Old Aug 9, 2011 | 10:18 PM
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
Re: 5.3 PINS
yes, but i still need to know which pins go where, i tried using your ls1 thread and found that a few pins weren't right, and i don't know where to start on the link u sent me earlier
Old Aug 9, 2011 | 10:30 PM
Pocket's Avatar
Car: 91 Trans Am
Re: 5.3 PINS
Werent right where? Several people have followed the guide successfully. You have the added benefit of having a 90-92 car which the guide was written on so all the diagrams posted can be applied 1:1
Old Aug 10, 2011 | 08:35 AM
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
Re: 5.3 PINS
like for instance, you said pin 8 goes to tps 5vlt rsv, on my harness it was like 48 or somethin like that... there are only a few wires that go with the pinup u've provided... and that's injectors
Old Aug 10, 2011 | 10:29 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: 5.3 PINS
before attacking any wiring, you really should spend a good amount of time on http://www.lt1swap.com/2000harness.htm like Pocket recommended; its very easy to get overwhelmed on a major swap like this. Get familiar with your 3rd gen wiring (i bought a helms manual) and know what you're seeing on the truck/4th gen stuff. having followed Pocket's guide myself, I know it works.
some of the truck wiring differs from the fbody wiring, its very important to know what your end product is going to be so you get the right tune as well.
Old Nov 27, 2011 | 12:44 AM
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
Re: 5.3 PINS
damn, shoulda read that way before i ever thought about doing wiring, makes things seem alot simpler now. thanks guys for the input.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
InfernalVortex
Apr 20, 2021 11:31 AM
ZZ3Astro
Aug 13, 2019 12:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Amillionoh7
Sep 11, 2015 11:36 AM
