No Power, turned key it all went dead.
Old Oct 24, 2011 | 10:54 AM
Igorealfast's Avatar
Car: 1988 Gta
Engine: 383
Axle/Gears: Stock
Car was running fine. Turned the key to start it, everything lit up, and the car just went dead. Battery has power, no power anywhere, like the battery is disconnected. Ground is good. Did a fuseable link go? Suggestions on where to start looking?
Old Oct 25, 2011 | 06:29 AM
Car: 1988 Gta
Engine: 383
Axle/Gears: Stock
Re: No Power, turned key it all went dead.
Well after 43 views, no one has a clue obviously. I did disconnect the wires from the starter, bought some new fuseable link and will splice that in. Don't understand why the Engineers just didn't fuse the wiring up top instead of fuseable links below. PITA. Well let's see if this works....
Old Oct 25, 2011 | 03:45 PM
xrgoose's Avatar
Car: 88 Trans Am
Transmission: 4 speed auto
Igorealfast, Im going to assume this is normal....as with mine i have my starter out atm. And nothing comes on...but when i just wired up the old crap starter, everything started recieving power again.
Old Oct 25, 2011 | 07:33 PM
TMMYJMMY's Avatar
Car: 1989 IROC
Engine: 5.7
Transmission: AUTOMATIC
Axle/Gears: POSI
Try checking the fuse up by the battery, it is kind of hidden by the headlights in a small case.
Old Oct 25, 2011 | 11:06 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
I had the exact same issue on my car last year. This might sound simple, but have you checked your battery connections? Take them out and clean them off. Some simple corrosion in there can cause the fuseable link to crap out when the load is applied at start up.
Old Oct 29, 2011 | 07:04 PM
Car: 1988 Gta
Engine: 383
Axle/Gears: Stock
Brand new battery, and clean connections. Cut out the fuseabale links, replaced them, and everything works fine now.
Old Oct 30, 2011 | 03:48 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
the fuse by the battery is for the fuel pump relay, in case you didnt know. the main battery wire goes to the starter, and has all the fusable links that come off the starter and go into the car. is common for these to give out over time, or the contacts to corrode since its under the car and constantly getting splashed with road grime. if possible, you might wanna coat the connections with a silicone grease to help cut down on future corrosion.
Old Nov 1, 2011 | 08:18 PM
TMMYJMMY's Avatar
Car: 1989 IROC
Engine: 5.7
Axle/Gears: POSI
Yea I know, but a lot of people including me have had that fuse blow or melt and would cause the car to not start.
Old Nov 1, 2011 | 08:29 PM
azfirebird's Avatar
Car: 1989 Firebird Formula 350
Engine: 5.7l
Transmission: 700r4 New Rebuilt 2011
Axle/Gears: 9 Bolt
Here is a great place to look just had this issue myself. ALTERNATOR sounds odd it had a bad diode which can not be tested. Changed the car runs great no more dead battery.
Old Nov 2, 2011 | 12:02 PM
travis401's Avatar
Car: 91 Camaro RS
he wasnt having a starting issue, he was having a no power issue. but yes, if the fuel pump isnt working then that would be the first place to look.
Old Jun 10, 2014 | 01:35 PM
ARthe1's Avatar
I'm having same problem no power but the battery is good ...don't have any idea wat it could be ...car was running fine but all of a sudden there's no power ...????
Old Jun 10, 2014 | 08:02 PM
no new tires's Avatar
Car: 88 IROC-Z
Engine: GEN 4 LY6 (going forged 408)
Transmission: 60E (going RPM LEVEL 6 4L80E)
Axle/Gears: 7.5" 3.42 (staying...)
Holy thread bump batman...
Old Jun 25, 2014 | 05:42 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Bumpy Ride
The most likely cause of your problem is a loose or dirty connection on the + battery cable at the starter.
Happy Racing !
When you see fog or “running” lights on in good weather beware. WLow performance driver ahead.
Old Feb 28, 2015 | 01:13 AM
91camarolsx's Avatar
[yQUOTE=Igorealfast;5081315]Brand new battery, and clean connections. Cut out the fuseabale links, replaced them, and everything works fine now.[/QUOTE]
Where are the fusible links at? I'm having fun the same damn issue as u were
Old Mar 2, 2015 | 04:09 PM
NINÅ's Avatar
Transmission: 765R4
Cruisin’ 4 A Fusin’
Fusible Links usually look like a one inch plastic rod in line with the wire and are located near the battery or at the starter.
Happy Racing !
Make Noise, Turn Left, Repeat
Old Mar 2, 2015 | 04:10 PM
Re: Cruisin’ 4 A Fusin’
Happy Racing !
Okay thanks I got it!
9192camaro
16
Feb 3, 2019 12:21 AM
Bryan F
Aug 18, 2015 02:28 PM
wayshegoes
Aug 17, 2015 12:00 PM
tnrednneck
Aug 13, 2015 08:57 AM
ZsTransAm
Aug 11, 2015 07:30 PM
