92 camaro RS high beam help!!!!!!
Old Jan 22, 2012 | 05:29 PM
jaypug92's Avatar
Car: 92 pontiac firebird & 92 camaro RS
Engine: 3.1 LHO V6
Transmission: Auto trany M5-A4
I have a 92 camaro Rs and its my daly driver but is really hard to see at night... heres my problem...... when i got to switch my high beams on i have to hit it really hard and when i do all my lights go out then i hit it again only the two high and low passenger side beams work none on the driver side if anyone had this problem and fixed it please help thanks...
Old Jan 22, 2012 | 05:35 PM
spotspot's Avatar
Car: 90 RS Camaro
Axle/Gears: stock
Re: 92 camaro RS high beam help!!!!!!
there is a little whit switch half way down the steering column replace it you should be fine
Old Jan 22, 2012 | 05:37 PM
jaypug92's Avatar
Engine: 3.1 LHO V6
its it hard to get to? and expensive?
Old Jan 22, 2012 | 05:45 PM
spotspot's Avatar
Car: 90 RS Camaro
Axle/Gears: stock
its not that bad i removed my column to get to it about an hour
Old Jan 22, 2012 | 06:03 PM
jaypug92's Avatar
Engine: 3.1 LHO V6
would i have to buy a whole new swtich or can i some how adjust it?
Old Jan 22, 2012 | 06:23 PM
spotspot's Avatar
Car: 90 RS Camaro
Axle/Gears: stock
they are adjustable you just have to see if the switch is bad or the adjustment is off
Old Jan 22, 2012 | 06:40 PM
jaypug92's Avatar
Engine: 3.1 LHO V6
do i need to take the whole steering column apart to get to it?
Old Jan 22, 2012 | 06:52 PM
spotspot's Avatar
Car: 90 RS Camaro
Axle/Gears: stock
i pulled the column out but also i was replacing the column so i dont know i will tell you its not easy to get to while the column is attached
Old Jan 22, 2012 | 08:48 PM
jaypug92's Avatar
Engine: 3.1 LHO V6
ok man thanks for your help
Old Jan 22, 2012 | 09:38 PM
spotspot's Avatar
Car: 90 RS Camaro
Axle/Gears: stock
your welcome
Linson
Aug 21, 2015 02:12 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
BBSDesigns
Aug 11, 2015 07:39 PM
