Brighter back up and reverse lights?
Old Feb 10, 2012 | 07:01 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
My backup lights suck and I can't see while trying to back up at all. At there any brighter lights I can get or buy so I can see??
Old Feb 10, 2012 | 08:37 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Brighter back up and reverse lights?
I swapped in some SilverStars.
JamesC
Old Feb 10, 2012 | 08:52 PM
Engine: L31 350
Are they brighter?
Old Feb 10, 2012 | 09:14 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
I've been wanting to try these, but I'd also be worried about the plastic reflector.
http://www.pplmotorhomes.com/parts/r...k-up-bulbs.htm
Old Feb 11, 2012 | 12:47 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
i put in a set of the SilverStars in my car, and yes they are noticeably brighter.
i'll never use the standard bulbs again.
if you get a set, just put one in on one side, set the park brake, turn the key on and leave the engine off and put it in reverse.
then go to the back of the car and block the SilverStar, then block the stock
bulb. of course you want to do it at night to really see the difference.
make sure your lens are clean, polishing them won't hurt either if they are clouded up.
Al, im with you, those bulbs you linked to would probably cook the lens pretty quick.
Old Feb 11, 2012 | 06:23 AM
Engine: L31 350
Okay then I know what I'm buying next then, it's sad when you can't even see to be able to back up into your own driveway to get into the garage when it's 9 at night and there is. It other lights
Old Feb 11, 2012 | 06:53 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
Always can go with an led strip or for low profile lights and get more light thatway
Old Feb 11, 2012 | 03:56 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
the reverse lights would not normally be on long enough to get that hot.
Old Feb 11, 2012 | 09:00 PM
Seafarer12's Avatar
Car: 92 GMC K2500 LD
Engine: 350 TBI with some mods
Transmission: NV4500
I would try getting the higher wattage bulbs. As far as the 50 watt bulbs. I would propably only use one of them though. I wouldnt worry about them over heating but overloading the circuit. I just put a 55 watt flood light on the back of my truck.
Old Feb 11, 2012 | 09:37 PM
Engine: L31 350
I'm just going to get thr silver stars and hope they help me
Old Feb 12, 2012 | 12:48 PM
Al Hasse's Avatar
I've take that into consideration, just haven't gone out and done it yet. My lights still work...
Still makes me cautious about the reflector though...
Old Feb 12, 2012 | 08:29 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
I feel that the 50W halogen will not harm the plastic tail lamp housing because they're not on for a very long time (relatively speaking).
I say this because the regular 1156 bulb will get pretty damn hot itself if left on for a long time. I wanted more light from the underhood light so I replaced the 93 bulb with an 1156. The 1156 actually cooked itself to death after 10-15 minutes. It got DANG hot too.
Old Feb 12, 2012 | 10:03 PM
Engine: L31 350
was going to order those 50 watt bulbs till i saw they were $10 a bulb. i can get to silverstars for that price.
justin57
Aug 20, 2015 07:05 PM
Fronzizzle
Aug 19, 2015 01:36 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
Omega
Aug 10, 2015 12:46 PM
hokis
Aug 9, 2015 03:57 PM
