No turn signals...running out of ideas.
Old Feb 18, 2012 | 01:19 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
I just noticed the other day that i dont have any turn signals on the car out of the blue. The hazzards still work however like normal. I pulled the turn signal relay (flasher?) and replaced it with no success. I also checked the fuse and it was good. Whats my next move?
Old Feb 19, 2012 | 01:22 PM
subroc's Avatar
Engine: 355 TPI
Re: No turn signals...running out of ideas.
Anyone?
Old Feb 20, 2012 | 03:51 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Turn & Learn
Turn the ignition key to the RUN position.
Using a test light
(the type for testing for voltage, not a continuity tester) probe the purple wire going to the steering column connector.
It’s the larger of the connectors located on the right side of the steering column.
If there’s power there, turn the blinker to the left position, then probe the
LIGHT blue wire at the same connector.
Is there power there?
Happy Racing!
After The Fourth Barrel Roll I Lost Control Of The Car
Old Feb 20, 2012 | 06:05 PM
subroc's Avatar
Engine: 355 TPI
Re: Turn & Learn
I fixed it!! Turns out the Haynes manual is lacking a bit in where the actual flasher is located. I thought i replaced it but instead i replace a relay right next to the hazzard flasher. I found the turn light flasher stuffed up above the convenience center and under the tach. It wasnt even c-clipped in like everyone on this board was saying. At any rate its all set now! Thanks for the help though.
Old Jun 30, 2012 | 11:18 PM
callmedylan's Avatar
Car: 1986 Camaro Iroc
Engine: 305 V8
Re: Turn & Learn
can you take a picture of it and post it here? i have the same problem and i have NO clue what the flasher looks like.
Old Jul 2, 2012 | 04:38 AM
subroc's Avatar
Engine: 355 TPI
Re: Turn & Learn
Here is a picture i grabbed off the net of what it looks like.
Mine was right above the convenience center in the car. I had to drop it down and feel around up there until i found it. It wasnt mounted to anything so i just yanked it down, unplugged it and plugged the new one in and problem was solved.
Old Jul 2, 2012 | 08:28 AM
gta_knight's Avatar
Car: 1987 GTA
Engine: 350 TPI w/ extras !
mine was just stuffed under the dash, i only discovered it when i had to move the convienience centre and it fell down !
Old Jul 2, 2012 | 02:56 PM
Engine: 305 V8
Re: Turn & Learn
great! thanks you guys. i'm gonna fix that today!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
greenyone
Sep 8, 2015 08:41 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
