Alternator tested ok but is it working?
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
I have a 1987 iroc-z 5.7 alternator it's wiring... when the cars running it shows 14 volts but when i pull the battery cable the engine shuts off... someone was telling me that some alternator have built in safety default? I took it in and had it tested it passed every test on the machine they put it on including the internal regulator which i suspected to be the culprit... So my only question is do they have some sort of safety default? like i said once the cable is pulled the engine dies...
Re: Alternator tested ok but is it working?
Bump
When you pull the battery cable on a running car they do...
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Never tried that with a CS style alternator or other
modern design alternator,but i know the old Si style
will continue to run the vehicle if battery removed with
engine running-make sure to do it at a low idle though
as the voltage can get unstable with the battery out of
circuit.My old '71 saab has a warning sticker on the
fenderwell that says the alternator will be"destroyed"
if battery disconnected while engine running...
Yeah i done it before too even on newer cars...my question still remains un answered... so does the alternator have a built in safety when the battery cables pulled... i have heard that some have somet type of safry default
Safety *
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
I also have an 87 that does the same. The cooling fan relay system shares a circuit with the three wire plug going into the rear of the alternator. I learned this because in addition to having a charging problem, I also learned that my entire coling relay system was missing (fans were both hard wired to run constantly). Through factory schematics it showed that one could affect the other.
My parts order comes in tomorrow and over the next week, I'll hopefully have the fans correctly wired and the alternator working again. I'll forward the wire colors next time I have access to my book.
1992rs/ss
Jan 31, 2025 05:10 PM
eightsixseven
Dec 16, 2024 01:50 PM
db057
Aug 11, 2015 10:11 PM
