Serveral electrical problems!
Old 06-08-2012, 06:45 AM
Sifo Dyas's Avatar
Hello,
I encountered serveral electrical problems with my 1989 2.8L V6 Firebird.
From one day to the other, the following components dropped out:
- Front and Rear lights don't work
- parking lights
- interior lights don't work
- the horn dropped out
- the door lock/unlock button is functionless
- this beep sound which appears if you start the engine doesn't appear
I already checked the fuses and they are OK. The interior of the car is dry.
For me this seems to be a strange combination of dropped out components and I don't have any idea where to begin my search for trouble shooting. My father mentioned, that maybe a marten could have destroyed some wires, but if so, which?
It would be great if someone has an idea what could be the reason for this strange electrical problems.
Best regards,
Peter
EDIT: When I tried it out just a few minutes ago, all worked well. But I want to know the reason for the problem anyway, to prevent it from coming back.
Old 06-09-2012, 06:10 PM
maxdvd91's Avatar
Car: 1989 chevrolet camaro
Engine: 2.8l v6
Transmission: 700r4 rebuilt
Axle/Gears: stock
Re: Serveral electrical problems!
i am having all of the excact problems try the ignition box under the dash did you by any chance peel the column a few weeks back or change the catylitic converter idk i cant seem to figure it out either damn 21 year old electricians once the car warms up the radio,headlights,lock pops the hatch pop and the cigg lighter cease to work
Old 06-11-2012, 03:01 AM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
did you check the relays under the dash too. I know it might not be a fix but maybe its there. Check the C100 on the firewall to make sure its not loose as its the complete harness for the headlights.
Old 06-11-2012, 02:01 PM
maxdvd91's Avatar
Engine: 2.8l v6
Axle/Gears: stock
someone told me to replace the ignition box ill try that ALSO
Old 06-11-2012, 03:56 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Components Dropped Out, Need More Glue
The int. lights, horn, door lock switches, and “beeper” are powered thru the ACC
fuse.
The “parking” lights are powered thru the
TAIL fuse.
Your problem is intermittent.
The source of the problem is a loose connection from the back of the fuse block at the aforementioned fuses’ junction to the Fusible Link on the starter.
That connection passes thru the Bulkhead Connector so also check that for loose or dirty pins.
Happy Racing!
If You’re Passed By Your Own Tire On The Track, It’s Time For A Pit Stop
Old 06-11-2012, 05:17 PM
maxdvd91's Avatar
Engine: 2.8l v6
Axle/Gears: stock
where is this bulkhead connector
Old 06-11-2012, 06:06 PM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
Wires can be a tricky thing. I fixed my dead power door locks that are set by an aftermarket GM remote key fob by locating a unattached orange wire. That single wire cleared up dead door locks, interior lighting, dome light, and a crazy sounding buzzing sound. I blew two 20 amp fuses while trouble shooting. I also fixed a separate dome light issue due to a loose connection. Apparently when I had the entire interior out for a redo, some how I did something that caused this loose connection.
When you trouble shoot wire and electrical problems you really need to figure what all is not working and go from there. Several unseemingly related issues can all be traced back to one thing.
Old 06-11-2012, 06:14 PM
maxdvd91's Avatar
Engine: 2.8l v6
Axle/Gears: stock
zz3 z28
i am having electrical problems with my 2.8l rs 89 camaro
-headlights
-hatch pop
-power locks
-acc lights inside and under the hood
-tail lights
-rev lights
-break lights
-radio
-cigarette lighter
-gas gauge stuck on E
when the car warms up all these things pop on and off while driving i cant drive it like this it does run i recently had to peel the column one day when i was driving it i the rain and the wipers were on i went to turn the car off with the wipers on with my screwdriver and it arced in the column and i blew the wiper fuse i popped in a new fuse and it worked about two weeks later i was driving home at night i might add and everything went out i had to drive 20 miles with no head or tail or break lights i got home and left the head lights on and at three in the morning they popped back on i have been told it goes through the bulkhead to the fusebox there are loose wire somewhere it runs off of the fusible links off the starter any info on this serious problem would be greatly apreciated
Old 06-13-2012, 04:07 PM
NINÅ's Avatar
Transmission: 765R4
I was thinking of racing boats and their terminology for a moment.
A more correct name would be Firewall Connector.
It’s located in front of the dash, on the firewall left side, below the relay bracket.
It’s a square-ish connector.
Happy Racing!
Old 06-14-2012, 05:10 AM
Sifo Dyas's Avatar
Re: Components Dropped Out, Need More Glue
Hi,
So some news: Right now I began to look for loose wires, but couldn't finde one yet. But under the dash board right besides the fuses block I found a connector plug which seems not to be connected to something:
And I found out, that the cigg lighter, the power mirrors and the electrical antenna also don't work.
A bit confusing was the following: The electrical trunk opener also doesn't work, but if I press the opener Button, the BRAKE light appears .
Old 06-14-2012, 02:48 PM
maxdvd91's Avatar
Engine: 2.8l v6
Axle/Gears: stock
try replacing your ignition switch its a 14 dollar part if that fixes it tell me and ill put the one i bought in
toones
01-06-2016 06:00 PM
Thirdgen89GTA
08-25-2015 06:40 PM
BlackphantomZ28
08-22-2015 01:00 PM
Tony Ferrarri
08-11-2015 07:59 PM
Quick Reply: Serveral electrical problems!
