Trunk Issues
Old Jul 2, 2012 | 06:01 PM
DanSchroeder's Avatar
Trunk Issues
So currently I am forced to take off my license plate to put the key in to open my trunk. The hatch works fine, but the switch in the center console will not open it. Kind of sucks to put the t tops away. Anyone know how to fix this? Is it just a matter of replacing the switch? Any help appreciated.
Thanks,
Dan
Old Jul 2, 2012 | 07:42 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Trunk Issues
You can pull the switch out and jumper around it and if trunk opens then your switch is bad.
Old Jul 3, 2012 | 07:11 PM
Re: Trunk Issues
How would I do this?
Old Jul 3, 2012 | 08:18 PM
Edwardgp's Avatar
Engine: 454-350
Re: Trunk Issues
The switch I believe snaps in and is removed by gently prying up on it[I think]. Then just take a little piece of wire and jumper across the terminals.
Old Jul 3, 2012 | 09:21 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Re: Trunk Issues
Another guy had this same problem the other day:
https://www.thirdgen.org/forums/elec...se-button.html
Old Jul 4, 2012 | 03:43 PM
Re: Trunk Issues
Found out it wasn't the switch. Had to disconnect the cig lighter to make the fuse stop blowing.
Old Jul 4, 2012 | 08:19 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Re: Trunk Issues
That fuse (Acc) powers about 10 things besides the hatch release; you didnt mention that. Glad you found the problem
Old Jul 6, 2012 | 11:26 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: Trunk Issues
Also your license plate should be mounted on a hinge so you can lower it to open the hatch manually.
Lon
Vojtush31
Oct 11, 2015 01:07 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
Chevy86 IROC-Z
Sep 7, 2015 01:13 AM
Glowsock
Sep 5, 2015 07:48 PM
