Turn Signal Relay Location
Old Jul 30, 2012 | 04:59 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Hey guys,
84 T/A. Silly question maybe, but as I've never had an issue with it, I've never looked for it. But where is the turn signal relay? Is it in the fuse box or stuffed up under the dash? Or somewhere else that I might need to look?
Old Jul 30, 2012 | 08:39 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Turn Signal Relay Location
The turn signals do not use a relay.The only thing that makes the turn signals flash is the flasher (thermal bi-metal circuit interrupter).
The flasher is located usually next to the fuse box, just clipped to it. But it could have been unclipped and can be elsewhere now.
The hazard flasher (is a different part) resides usually in the convenience center which is under the dash to the right, towards the center console.
Both flashers have only 2 prongs, that identifies them easily.
Hope this helps.
Lou
Old Jul 30, 2012 | 08:50 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Hope this helps.
Lou
Thanks for the reply, I'll take a look. I just remember on my 67 Camaro that they were round cylinders just under the dash. The reason I need is that I'm switching to LED lights and apparently need a "voltage" flasher, rather than an amp draw flasher. At least that's what the maker of the LED's is telling me. Otherwise they'll just be a strait on as if a light burned out.
Old Jul 30, 2012 | 09:08 AM
BigBadLou's Avatar
Engine: TPI
The LED maker is telling you the truth. Once you install LED bulbs, your load-dependent flasher will stop flashing and you will need to replace it with an electronic version.
They have gotten so cheap that you can find one at your local car parts store for just $12 nowadays. Oh, in your case, you will have to probably order one from the Internet since the GM flashers might not be readily available in your location. They sell those flashers
on Amazon too on Amazon too
And you are right, the GM flashers are just cylindrical objects under the dash somewhere. They are easily identifiable by their two prongs at a 90-degree angle.
Hope this helps.
Lou
Old Jul 30, 2012 | 09:19 AM
Ozz1967's Avatar
Car: 1984 Trans Am
They have gotten so cheap that you can find one at your local car parts store for just $12 nowadays. Oh, in your case, you will have to probably order one from the Internet since the GM flashers might not be readily available in your location. They sell those flashers on Amazon too.
Hope this helps.
Lou
Thanks Lou,
I really appreciate it. I've been driving illegally for the last year because I don't have "Amber" turn signals. I've modified my 88 GTA style lamps to be like the 91-92 lamps with the amber turn signals on the very outside. Now I won't have to worry about the cops pulling me over. Again, I really appreciate the help!
Old Jul 30, 2012 | 09:30 AM
BigBadLou's Avatar
Engine: TPI
Ozz, if your vehicle was imported with red turn signals, it should have an exception from the import authorities and you should get no trouble from the police. But if they just like to pull you over to hassle you and check our your ride, that is understandable.
Now what would happen if you were to revert your tail lamps back to all-red turn signals and if you also added a sequencer to the turn signals to make them flash directionally? Would they throw a fit?
Old Jul 30, 2012 | 10:12 AM
Ozz1967's Avatar
Car: 1984 Trans Am
I brought my car over here when I was stationed here in 2011. England doesn't have any laws for import exceptions. Even guys with 1960's Camaro's and Mustangs have to do the light conversion. Also, sequencial turn signals are totally illegal. $160.00 fine for either not being correct. No grace period to fix it though they tend not to give tickets for the same thing in the same day, unless it's a traffic violation.
They also have yearly Vehicle safety checks on all cars over 3 years old. $70.00 per year for the inspection. $350 a year to get tags on cars over 10 years old. More for newer cars. They really hit you hard with this stuff here.
Old Apr 9, 2015 | 06:25 PM
Lilrabbit's Avatar
Car: 1983 camero cfi
[QUOTE=Ozz1967;5340467]Hey guys,
on my 83 camero. Take the under dash panel off and a metal bracket held by 2 small screws closer to the radio. On top of that bracket you'll find the blinker relay.
Fronzizzle
Mar 18, 2019 08:29 PM
z28_AJ
Aug 27, 2015 08:59 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
