is this my vats module
Old Nov 11, 2012 | 04:38 PM
91camarox's Avatar
Car: 91 camaro rs
Engine: 305 tbi
I'm lost as to what's what
Old Nov 11, 2012 | 06:25 PM
91camarox's Avatar
Car: 91 camaro rs
Engine: 305 tbi
Re: is this my vats module
Or this
Attached Thumbnails is this my vats module-20121111_155501.jpg   is this my vats module-20121111_155453.jpg
Old Nov 11, 2012 | 07:16 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Your 2nd post, pic on the left.
Old Nov 11, 2012 | 07:51 PM
91camarox's Avatar
Car: 91 camaro rs
Engine: 305 tbi
The on where u can just see the connector behind the air duct
Old Nov 11, 2012 | 09:49 PM
jf94's Avatar
Car: 92 Camaro RS
Engine: 3.1L
yea that's it. I just ripped mine out yesterday and wired in a bypass module.
Old Nov 11, 2012 | 09:51 PM
91camarox's Avatar
Car: 91 camaro rs
Engine: 305 tbi
Do u have a guide for wiring jn the bypass I play on doing it as well
Old Nov 11, 2012 | 09:58 PM
jf94's Avatar
Car: 92 Camaro RS
Engine: 3.1L
I'm unsure of which module you're using but assuming you're using the one I did (module) I can tell you how I wired it up but I don't remember off the top of my head and the car is at the shop I work at (getting ready to pull the knockin 3.1 and throw a LQ4 in it) so you'll have to wait till tomorrow.
Old Nov 12, 2012 | 02:32 AM
91camarox's Avatar
Car: 91 camaro rs
Engine: 305 tbi
ThIs is the one I bought http://pages.ebay.com/motors/link/?n...d=280981183631
Old Nov 12, 2012 | 06:27 PM
jf94's Avatar
Car: 92 Camaro RS
Engine: 3.1L
Still haven't had a chance to look at the car but here's the way it should be wired up.
The red wire goes to a switched power source.
The white wire beside the red one goes to the Blue wire at pin A2 on the connector that connects to the original VATS module.
The other white wire is grounded depending on the car you have. Assuming your car is a 91 from your name then this wire will not need to be grounded to work with your car.
The black wire is just simply a ground.
http://www.xdponline.com/documentati...***_Module.pdf
Check that link out. There is a diagram that shows you how it should be wire up.
InfernalVortex
Apr 20, 2021 11:31 AM
RS Reaper
Oct 17, 2018 07:52 PM
dusterbd
Sep 29, 2015 08:40 AM
AmorgetRS
Sep 28, 2015 09:33 PM
tattmann
Sep 27, 2015 05:20 PM
