Fixed my speedometer
Old Dec 3, 2012 | 12:00 PM
xavier_pr84's Avatar
my speedometer has been in a working when it wants to mode since i got the car in june. At times it would work sometimes it wouldn't i took the gauge cluster out too fix my tach which i did fix anyway i took the gauge cluster out and removed the motherboard on the speedometer it had carbon all over from where i dont know. i cleaned it up real good and put it back in and bam !!! i have a working tach and speedometer !!!!!!!!!!!
the dirty motherboard i was talking about
My fixed tach !!!! im so happy
this place rocks
Old Dec 3, 2012 | 12:30 PM
JesseShredd's Avatar
Car: 1992 Camaro RS
Engine: 1978 L82 355
Re: Fixed my speedometer
How did you fix the tach?
Old Dec 3, 2012 | 02:21 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
I assume using this old sticky thread: https://www.thirdgen.org/forums/elec...meter-fix.html
Old Dec 3, 2012 | 02:27 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Hey Lou, what's that black crud all over his board and where did it come from?
Old Dec 3, 2012 | 02:36 PM
BigBadLou's Avatar
Engine: TPI
If I had to make an educated guess, I would say that is cap blew and spilled all over the board. The top does look bulgy from this angle (judging from the change in reflectivity). The electrolytic fluid is not an insulator, quite the opposite, so it probably added unexpected parasitic capacity to many places in the circuit, wreaking havoc on the readings.
But again, it's just a guess.
Lou
Old Dec 3, 2012 | 02:41 PM
Car: 1992 Camaro RS
I assumed that also but would like to hear different if not.
Old Dec 3, 2012 | 03:05 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
It does look kinda puffy on top and the black stuff is right there at the base near a pin apparently. I've seen a bunch of popped caps in mother boards and none looked quite like that though. Never seen one bleed that black and it just looks strange how it gathered around those parts where they went thru the board. That looks kinda charred. Weird.
Old Dec 3, 2012 | 04:43 PM
dont know what it was but once i cleaned it up it works like a charm
Old Dec 3, 2012 | 04:44 PM
yep thats the one look at page 4 and above very easy to do
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Elephantismo
Feb 13, 2019 12:51 AM
92firebirdguy
Sep 1, 2016 07:53 AM
BWilcox
Sep 20, 2015 12:19 PM
TrevinE
Sep 14, 2015 03:20 PM
