83 firebird headlight wiring diagram
Old Dec 27, 2012 | 06:11 PM
Dskeezy16's Avatar
Car: 1985 Firebird Trans Am
Engine: ls1
Transmission: t56
Axle/Gears: 8.8 Ford 3:73's
Just wondering if anybody knows where i can find or has a wiring diagram for an 83 firebird. I really need one in order to move forward with making mine work.
Old Dec 28, 2012 | 06:30 AM
82tarecaro's Avatar
Re: 83 firebird headlight wiring diagram
What is wrong with them?
Old Dec 28, 2012 | 07:34 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Maybe something helpful in the following link:
http://www.austinthirdgen.org/index.php?pid=19
JamesC
Old Dec 28, 2012 | 08:36 AM
82tarecaro's Avatar
Here is 1982 - 1983 should be similar, if not the same.
Old Dec 28, 2012 | 10:33 AM
Dskeezy16's Avatar
Engine: ls1
Transmission: t56
Thank you this should help me alot! The problem with them is that when i flick the switch i can see both ***** on the motors make about a quarter turn or less and stop, if i get the headlights up manually they wont even try to go back down.
Old Dec 28, 2012 | 12:06 PM
82tarecaro's Avatar
Test for power at the motor, but what you describe sounds like you may need to rebuild those motors.
Old Dec 28, 2012 | 07:10 PM
Dskeezy16's Avatar
Engine: ls1
Transmission: t56
Neither light would go up with direct power, the motro doesnt even try to spin
Old Dec 28, 2012 | 07:14 PM
82tarecaro's Avatar
Does it feel like the motors won't go up because they are binding up inside, or that there is no power to the motor? The motors are rather complicated inside with a limit switch that is triggered in either direction when the headlights reach the end of their travel. Tension on the system causes the switch to trip. So if the motors are messed up inside that could trigger the limit switch if they are hard to move or binding in any way.
How do they move when you crank them manually? Are they smooth and move easily?
Old Dec 28, 2012 | 08:08 PM
Dskeezy16's Avatar
Engine: ls1
Transmission: t56
They move pretty easily the drivers side one likes to fall down a little bit after you crank it up, other then that its all smooth
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Caspar
Jun 19, 2016 11:19 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
tnrednneck
Aug 13, 2015 08:57 AM
