Starter issues
Old Aug 4, 2013 | 11:08 AM
racerx520's Avatar
Starter issues
I have hooker shorty headers on my TPI, and when i run the car for too long and shut it down, it wont start until it either cools down for a half hour + or i get some water and hose down the starter to cool it off. I was wondering if anyone else had this similar problem and what they did to remedy it. the starter came with a really cheap heat shield, but it wouldnt fit under the headers.
Old Aug 4, 2013 | 11:32 AM
Yenipenny's Avatar
Car: 92 RS Heritage
Re: Starter issues
Starter heat soak is a rather common problem especially with some "aftermarket" starters and headers. About the only sure fix is to buy one of the high torque mini-starters. Your starting problems will be gone.
Old Aug 5, 2013 | 10:35 AM
racerx520's Avatar
Re: Starter issues
what if i use an original starter? my father had one sitting around and says its from an 89 SBC. do you think itll still have the same problem?
Old Aug 5, 2013 | 12:35 PM
whoaru99's Avatar
Car: 1991 Z28 w/G92
Engine: 5.7 TPI
Re: Starter issues
Yes, probably.
Old Aug 6, 2013 | 11:59 AM
racerx520's Avatar
Re: Starter issues
damn.....ok.
thanks
Old Aug 6, 2013 | 12:07 PM
Blue1990camaro's Avatar
Re: Starter issues
on summit racing .com u can buy a starter bag, it wraps around the start so its not like a matal shield, its made out of fire proof material and seems to work very well, had one on my Nova
Old Aug 10, 2013 | 05:15 AM
ajStyles2015's Avatar
Car: 1989 & 1990 RS V8 TBI
Engine: 305 5.0 L
Re: Starter issues
Does this starter bag you talked about have a technical name? I searched it and could not fin anything. Maybe you could send me a link if you know where to find one???
Old Aug 10, 2013 | 09:09 PM
diamjim's Avatar
Car: 1992 RS Camaro
Engine: 383
Re: Starter issues
I'm having a very similar problem. When I drive the car 20 minutes or more it won't crank. A mechanic shorted the starter with a big screw driver to make it crank. I had the alternator tested and it was ok. What are your symptons?
Old Aug 10, 2013 | 10:13 PM
racerx520's Avatar
Re: Starter issues
if he shorted the starter then that means the solenoid is your issue. i dont get anything out of my starter, which may mean its the solenoid too. I would like to see this starter cover to see if that'll help.
Old Aug 11, 2013 | 04:04 PM
diamjim's Avatar
Car: 1992 RS Camaro
Engine: 383
Re: Starter issues
Car is in the paint shop right now. The reason, I thought it was similar to your problem was it started right up after sitting a couple of days.
Old Aug 11, 2013 | 04:20 PM
Aaron_SK's Avatar
Car: 1985 Sport Coupe
Engine: 3800 Series II Turbo
Transmission: 4th-gen WC T5
Axle/Gears: 3.27 BW Limited
Re: Starter issues
Swap to an LT1 starter (factory mini-starter, baby!) The old direct-drive starter puts the solenoid too close to the exhaust.
Take a moment to consider your tune. Mix too rich or timing too retarded will both cause excess exhaust heat and make this problem worse.
You also might consider a relay trigger for the solenoid. GM did a poor job of wiring the ignitions switch in these cars, especially the ones with VATS. Damn solenoid trigger is a mile long!
Old Aug 11, 2013 | 04:44 PM
Joe Tag's Avatar
Re: Starter issues
Wrap your headders and get a heat shield. Also, a remote solenoid would help. Seen a few threads about it.
Old Aug 11, 2013 | 08:38 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Starter issues
Originally Posted by Yenipenny
SBC Starter heat soak is a rather common problem
With well documented solutions.
https://www.thirdgen.org/solenoid
http://www.chevyhiperformance.com/te..._no_start_fix/
http://www.streetrodstuff.com/Articl...tart_Problems/
Old Aug 11, 2013 | 09:11 PM
Engine: 305 5.0 L
Re: Starter issues
damn.....ok.
thanks
Hey man did you ever end up putting in that high torque mini-starters?? If you did how did it work out for you? I am thinking about putting one in cause I'm having the same hot no start problem. But wanted to see how it worked out for you before I spend the money on it.
Old Aug 13, 2013 | 10:58 AM
manolis1969's Avatar
Car: klowny1969 <-youtube 4 3rd gen vids
Engine: subscribe to klowny1969 on youtube!
Transmission: subscribe to my channel on youtube
Re: Starter issues
Here is a vid of how to wire a remote mount solenoid on a thirdgen:
also subscribe to my channel for free to be updated on future thirdgen vids, just search for KLOWN1969 on youtube!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
TBRays98
Sep 6, 2015 05:05 PM
greenyone
Sep 2, 2015 03:39 PM
