lost pellet dont know resistance for my passkey
Old Aug 24, 2013 | 11:34 PM
bugman40284's Avatar
Car: 1990 camaro rs
Engine: 305 tbi
Transmission: 5 speed
Axle/Gears: stock
305 1990 camaro rs manual trans all stock for now.
So here is the problem, I went to the movies tried to start the car and got power but no starter and no fuel.
Next day I look at my key and the freaking pellet fell out, I have no idea the resistance I have been going through the resistors I bought from radio shack and tying different ones together getting the desired resistance but with no avail
Quickly, is there a resister sort of dimmer I could try out I've seen a radio one that looked promising.
But is there a way to type in my Vin anywhere to find my resitance because unfortunately the car isn't in my name yet
Next and last thing what should happen when I find the correct resistance, as in the security light will turn off or blink or something useful, any sort of help would be appreciated
Old Aug 25, 2013 | 03:11 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: lost pellet dont know resistance for my passkey
https://www.thirdgen.org/forums/tech...formation.html
Read this for understanding how VATS works
https://www.thirdgen.org/vats_passkey_system
You could , would have to set and check the resistance by the chart in link above with a DVM ,then connect it and if not the correct ,
change the resistance value while waiting 5 minutes for the system to reset.
NB;
every time you turn the key the timer resets to zero again
Old Aug 25, 2013 | 03:19 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Luckily, my car doesn't have VATS so I may not have the most current or correct info. Have you tried your favorite search engine?
http://www.vatskey.com/vats/vatskeylock.htm
You didn't lose your key but this may be one option:
http://www.vatskey.com/vats/lostvatskey.htm
I'd trust responses from other members with real experiences:
https://www.thirdgen.org/forums/elec...tor-value.html
https://www.thirdgen.org/forums/elec...stor-help.html
https://www.thirdgen.org/forums/elec...plain-why.html
https://www.thirdgen.org/forums/elec...ce-values.html
http://www.google.com/search?q=vats+...en-US:official
Old Aug 25, 2013 | 11:03 PM
Spaceboy1980's Avatar
Car: 1990 Camaro RS
Engine: L31
If you have a multimeter, I would get a potentiometer from radio shack and set the resistance for the first value from the table, if that doesn't work then try the next value, etc until you hit the correct one.
Old Aug 26, 2013 | 12:25 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Originally Posted by Spaceboy1980
.... set the resistance for the first value from the table, if that doesn't work then try the next value, etc until you hit the correct one.
Kinda , exactly like what I already said in post # 2 above
Old Aug 26, 2013 | 12:27 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
There must be a echo in here
Old Aug 26, 2013 | 01:45 AM
Car: 1990 Camaro RS
Engine: L31
Only I simplified it so it is understandable. I told him what he needed and where to get it, you gave him acronyms he may or may not know.
There was nothing wrong with my post.
Old Aug 26, 2013 | 07:41 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
That is why we have Google for those intelligent enough to punch 3 letters into the Google search box and hit enter.
( as opposed to coming back here and asking ,whot tis a DVM ???? as is usually the case)
Old Aug 26, 2013 | 11:15 AM
Car: 1990 camaro rs
Engine: 305 tbi
Axle/Gears: stock
OK guys enough with the arguing it's all done and figured out thanks for the help in the end I found an old stereo and ripped the volume control off and used that, took me a couple hours but it started right up just as I was losing hope sooooo thanks again for the help
Old Aug 27, 2013 | 12:54 AM
Car: 1990 Camaro RS
Engine: L31
No kidding, never thought I'd catch flack for helping a fellow out. Apparently you're just supposed to google it all and not ask any questions. :/
Anyway, I'm glad you got it running. If you measure the resistance of what you have your dial at, you can build you a resistor pack and wire it into the harness. If you ever park anywhere you are uncomfortable, you can just unplug it and take it with you.
Old Aug 27, 2013 | 05:38 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Apparently you're just supposed to google it all and not ask any questions. .
You may very well say that.
Many of the questions asked on here are not 3rd Gen specific and are just general engine questions.
The classic " my car won't start ,what could be the problem ?" could easily be narrowed down through a Google search bringing up something like this
http://troubleshootmyvehicle.com/gm/...t-a-no-start-1
Problem being everyone now expects instant answers to their car problems.
There was a time where unless you were friends with that grumpy mechanic at the other end of town ,you actually had to work on your car ,
learn it's systems and how it operated and how to sort problems out on your own.
Now all you do is pull out your cell , type in HELP and get someone to walk you through the problem without actually learning anything.
Too bad if your car stops in the boondocks and your cell battery is flat
Old Aug 27, 2013 | 08:54 PM
Car: 1990 Camaro RS
Engine: L31
You can't learn without asking questions. You are right in the fact that he was spoon fed what to do, but not why to do it. I guess it depends on your audience on if they want to know what or why.
Old Aug 28, 2013 | 03:23 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
You are right in the fact that he was spoon fed what to do, but not why to do it. .
NB
My comments were not directed at this OP ; he correctly diagnosed what his starting problem was and went about fixing it before starting this thread
His question about a variable resistance to speed up finding the correct value is perfectly valid (and 3rd Gen related )
Old Aug 28, 2013 | 11:28 AM
Car: 1990 camaro rs
Engine: 305 tbi
Axle/Gears: stock
All we need is love you guys both have very valid points but the bickering is getting to me what you guys both said was almost the same, maybe said a little bit different but in the end you both help me loads so again thank you
RedLeader289
May 28, 2019 01:47 PM
Elephantismo
Feb 13, 2019 12:51 AM
apie2546
Oct 16, 2016 02:24 PM
Jynx88
Oct 4, 2015 08:19 PM
3.8TransAM
Sep 27, 2015 08:37 PM
