Need turn signal help
Old Feb 22, 2014 | 06:16 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
Hey guys, so my front left turn signal and left fender turn signal don't light up when I turn on the parking lights and I get the warning light on the dash, when I remove the front turn signal bulb the fender signal starts working, tested the socket with a test light and got no power, I put a new bulb and flasher in, do you guys think I need a new socket?
Old Feb 22, 2014 | 07:06 PM
Ransford2987's Avatar
Car: 1990 IROC-Z/1980 Firebird
Engine: 5.7 TPI
Re: Need turn signal help
I would trace the wiring out as far as you can and look for a break or a ground. Just to make sure before you spend the money on something you don't need.
Old Feb 22, 2014 | 07:23 PM
TylerSteez's Avatar
Engine: 383 stroker
Forgot to mention that whenever I put on the left turn signal both the fender light and front signal flash fine
Old Feb 22, 2014 | 08:45 PM
Engine: 5.7 TPI
That sounds like a ground to me. You can check the socket, but if it works when you turn on the the turn signal, then the socket is probably fine. I have attached a diagram for your reference. Granted it's from a 1990, but the wiring should be extremely similar. There are two power sources that go to those lights: the head light switch and the turn signal switch. It appears that you have a ground somewhere from the headlight switch power to those lights.
What happens when both the parking lights and the turn signal are on?
Old Feb 22, 2014 | 08:51 PM
TylerSteez's Avatar
Engine: 383 stroker
Thanks for the help, when I put the turn signal on while the parking lights are on the turn signal works fine and how it should but once it's off it goes back to no light, also before it completely stopped working every time the light went out I was able to jiggle the bulb and get it to work again
Old Feb 22, 2014 | 08:58 PM
Engine: 5.7 TPI
Maybe you do have a loose wire or something in the socket. Try messing with the wire(s) with the parking light on and see if you can get it to work. Looking at that diagram, both RH and LH side lights are powered by one supply from the headlight switch, so if it were a ground from the headlight power, it would most likely be affecting both lights. Check the light brown or tan wire that goes to both sides for breaks. If there are none, it just might be that socket...
Old Feb 22, 2014 | 09:02 PM
TylerSteez's Avatar
Engine: 383 stroker
I'll chase the wires down tomorrow morning and get back to you, might even just replace the socket to see if it solves it. Thanks for the diagram and the help man
Old Feb 25, 2014 | 04:53 PM
gallaire's Avatar
Car: 91 trans am
Engine: ?
Transmission: auto 4sp
Axle/Gears: posi
help me signal lights no go fuse is good it was just working,m press brake makes interior lights go onb wtf uhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh
will this car electrical prob ever end just want to ride beging to descuraged
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
TrevinE
Sep 14, 2015 03:20 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
