Dead short/power drain after horn wire got pinched
Old Mar 16, 2014 | 09:37 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Dead short/power drain after horn wire got pinched when I had to remove steering wheel. Figure it out after the fuse blew, unplugged horns [ don't work, just click] and even removed wire from steering wheel so it can't be " grounded" but dam if my battery isn't still going flat after sitting a day or two still, as if its still doing it.
If the horns are unplugged and the ground wire in wheel removed, I dunno how im still draining power???
Old Mar 16, 2014 | 10:04 AM
Joe Tag's Avatar
Re: Dead short/power drain after horn wire got pinched
The relay will still draw power even when the horns are unplugged. This is of course assuming it IS the horn causing your drain.
Old Mar 16, 2014 | 10:16 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
It was the only and last thing to happen.
unless beating the wheel on and off did someting else???
IM not good with electrical stuff.
Old Mar 16, 2014 | 10:19 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
It was "on" until the fuse blew, mabey that relay is shorted? where do I find it?
Old Mar 16, 2014 | 10:32 AM
Joe Tag's Avatar
The horn relay is on the right side of the steering column, by the diagnostic port. In the courtesy center.
Old Mar 16, 2014 | 04:49 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I guess the only way to know for sure if thatwas it, is to see if the battery goes dead or down in a day?
Old Mar 18, 2014 | 01:03 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
might be in the clear, horn relay was warm when removed after battery only hooked up a few min.
horn relay is next to hazards relay
Old Mar 21, 2014 | 12:28 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
OK well that didn't fix it, just clicks today, no start.
Old Mar 21, 2014 | 02:05 PM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Check your ignition cylinder and make sure something isn't causing it to hang internally in the run position or something, even though the key is out. Just an idea
Also, dumb question, but: is your dome light turned on?
Old Mar 26, 2014 | 07:01 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
nothing obvious, gonna tear into it soon, did have both the horn,acc fuse and tailight fuse go out in recent times. Maybe something cross related.
just gonna gut interior so I can lay under the dash easier, can check T5 fluid and work on that digital gear indicator
https://www.thirdgen.org/forums/elec...indicator.html
Old Mar 31, 2014 | 06:03 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Well Im starting to think maybe it was the cig lighter, I removed center console to re-seal shifter. With that stuff undone, power loss has stopped or seems to. Doesn't spark when neg is touched, multimeter inline for neg shows nothing.
Old Apr 5, 2014 | 01:17 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
sat for 3 days, started up just fine and went......
Im sure I fixed some things, but had to get a new battery also. So its a give and take.
Batt in there I got free in 09 out of the bed of a junk truck, was marked as bought on 02, I had it on a float charger for a while before first use.
Was a NAPA battery, so I bought another NAPA battery, 12yrs was a long time for one to last.
Old Apr 5, 2014 | 01:41 AM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
wayshegoes
Aug 17, 2015 12:00 PM
djmarch
Aug 9, 2015 05:27 PM
Kaweh
Aug 9, 2015 02:54 PM
Amillionoh7
Aug 7, 2015 01:24 PM
